586,115 active members*
3,232 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > View parameter#5131 & 5132 - Fanuc 21i-T
    Mar 2008
    10
    Question View parameter#5131 & 5132 - Fanuc 21i-T
    From the controller [Fanuc 21i-T], I would like to view parameters #5131 & 5132.
    When I go into the System/parameter page, the parameters stop at 4150 [or around there] and start again at 6000.
    Does anyone know how to view the 5000 parameters on this controller?
    Thanks for any help you can offer!
    Mar 2010
    View parameter #5131 & #5132
    Not sure why these are not visible, but an easy way view them is to transfer them to an unused # parameter.
    #100=#5131
    #101=#5132
    Give it a try!
    Mar 2008
    10
    Didn't think of doing that!
    [doh~]
    THANK YOU!
    Aug 2011
    2517
    those parameters are some of the settings for the canned cycles. perhaps your machine has some other screen to configure that via a MTB-added screen.
    Otherwise, the easiest way is just punch out all of the parameters to a PC via RS232 then look at the resulting text file and you can see everything.
    If you can't see them but need to change them you could probably use G10
    Mar 2008
    10
    Thank you!
    The parameters are part of the G71 canned cycle.
    I don't want to change the settings, I just wanted to see what they were at before I ran a different configuration of the program. I needed to 'show' them to someone else to end a disagreement.
  1. Fanuc 11 G54 parameter
    By staffb68 in forum Fanuc
    Last Post: 06-26-2013, 08:21 PM
  2. FANUC 6T PARAMETER
    By hiiesalu in forum Fanuc
    Last Post: 01-23-2013, 08:33 AM
  3. Fanuc parameter 901
    By mistux in forum Fanuc
    Last Post: 12-04-2009, 06:28 PM
  4. 18i hidden parameter view/change?
    By john k in forum Fanuc
    Last Post: 12-22-2006, 07:58 AM
  5. parameter fanuc om-d
    By dlmusinage in forum Fanuc
    Last Post: 05-17-2006, 10:54 PM
