why is the popping up...? UsingV25
It pops up and never even trys to start a tool path simulation
anyone have any clues? or answers.... Thanks!
Have you set bobcads launch Icon to run as administrator?
Have you made some type of install path other than default?
C:\BobCAD-CAM Data\BobCAD-CAM V25\MachSim\BobCAD_Mill\BobCAD_Mill.xml
This happens if you create a new machine and delete the original "BobCAD 3 axis machine", this deletes the original XML file so you will need to put that file back in to your BobCAD-CAM Data folder here:-
I have attached the files you need here Zipped up in it`s original folder, just unzip it and then paste the folder as is into the \MachSim folder, that should get your sim working again.
Then just add a new machine and then select that as the default and leave the original one in the file
Hope that helps![]()
Regards
Rob
:rainfro::rainfro::rainfro:
