586,117 active members*
3,488 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Gecko g540 & SSR voltages
    Jun 2012
    hello everyone, im tring to set up my mist coolant system and i got few questions
    im using gecko g540 driver + 48v 7.3a power supply
    in addition i got 24v 1a power supply for my fans
    i bought SSR with 3-36vdc input - 24-380vac output
    im using output no' 5 at the gecko 12pin block
    is it possible to use the 24v power supply for the dc side without any voltaeg dropage
    and if so, which way should i connect it
    i attached a scheme showing what i tought of doing
    thanks !
    Mar 2007
    2083
    Hi Drorness
    does this help ?
    John
    Jun 2012
    Quote Originally Posted by john_100 View Post
    Hi Drorness
    does this help ?
    John
    hello john, thank you
    im using 48v power supply for the gecko g540
    in addition i got 24v power supply for my fans and now for the ssr
    do i need to connect the negative of the 24v power suplly to the negative of the 48v powersupply?
    Mar 2007
    2083
    Hi
    yes , connect the negative terminals of both power supplies to the G540
    GND terminal 12 as on page 8 of the G540 manual V8 :-
    http://www.geckodrive.com/images/cms...8%20Manual.pdf
    John
  1. Ok.... I like the Gecko G540, but...
    By Bob La Londe in forum SmoothStepper Motion Control
    Last Post: 06-01-2011, 11:55 PM
  2. Gecko G540 ??
    By gitarre10000 in forum DIY CNC Router Table Machines
    Last Post: 11-24-2010, 04:55 AM
  3. Gecko G540
    By Deb.bosch in forum Stepper Motors / Drives
    Last Post: 03-20-2010, 02:40 AM
  4. Gecko G540
    By rotger in forum Servo Motors / Drives
    Last Post: 06-02-2009, 06:43 PM
  5. gecko g540
    By Teyber12 in forum Benchtop Machines
    Last Post: 05-31-2009, 08:23 PM
