586,912 active members*
3,704 visitors online*
    Feb 2006
    77
    828d Thread re-machining
    Hi all,
    We just got a new lathe with the 828D control. Can upload some pictures if anyone is interested.
    It has a few dramas but won't get into it now.
    What I Want to do is some thread re-machining but just cannot find the sync point button.
    Did it once now can't remember!
    Also does anyone know where to find a shopturn manual for this control? Can only find the 840D manual on the Siemens web site.
    Cheers
    Feb 2006
    77
    Found it, would still like the correct 828D manual though.
    Dec 2010
    50
    Here is the link to the 828D manuals Siemens Industry Online Support - Automation Service, Automation Support, Simatic Service, Simatic Support, Technical Support, Technical Consulting
    You will find many manuals related to all aspects of 828D. For turning, you can start with this manual: Siemens Industry Online Support - Automation Service, Automation Support, Simatic Service, Simatic Support, Technical Support, Technical Consulting
    The 828D and 840D sl share the same ShopTurn software so the manuals are often listed as 828D / 840D sl
    If you don't find what you are looking for, post a reply.
    Apr 2002
    5003
    I have no experience with Lathes, but for your synchpoint, I would first try, if the control can use the M19 command, alternatively you can bring your spindle with Spos=xyz to a definite position, wheras xyz stands for a angle from 0-359.999°. If you have a non modulo axis as spindle than your angle can be bigger than 360°.
  1. Thread spec for camera lens filter thread
    By cmays in forum MetalWork Discussion
    Last Post: 07-20-2016, 10:43 AM
  2. Long full acme thread machining
    By Jelle_b_k in forum MetalWork Discussion
    Last Post: 08-20-2011, 02:01 PM
  3. cam for xyz 560 mini mill with 828d controller
    By badassdevil in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 01-14-2011, 11:31 PM
  4. machining angled thread
    By koola in forum MetalWork Discussion
    Last Post: 08-13-2009, 02:36 AM
  5. machining left I D thread and O D knurling
    By chipcrazy in forum MetalWork Discussion
    Last Post: 08-09-2009, 10:36 PM
