Advantages
Equipped single side or double-sides hydro cylinder to keep the machinery works smooth and steady with noiseless, it is convenient and long working life.
Safe manual operation in case of black out, emergency stop can give protection when some urgency happened.
The pit should be 15-30 cm, the height of the top is unlimited.
Custom made according to the surroundings.
Install inside or outside of the multistoried building.
Imported and domestic pump stations are optional.
Hydro-cylinder and sealing element adopt imported parts.
Imported controlling system is optional. (Schneider, Siemens, etc)
Vertical lifts Applications:
Stationary lead rail lift provides fast, efficient, convenient and safe access to mezzanines, balconies, basements, and any levels in multistoried building. It can be installed indoor and outdoor applications.
Availabilities:
Lifting height: 1.65-20m; Load: 0.1-100T
12 months from delivery apart from artificial damage
Free lifelong technical service.
Safety:
Hydraulic elevators not only have all safety device of the traditional elevator, but also have the special safety system hereinafter.
Spillover valve, it can prevent high pressure when the machine moves up.
Manual emergency valve, it can go down to the nearest floor and open the door when you meet an emergency.
Manual pump: it can move up the nearest floor and open the door when you meet an emergency.
Pipe fracture valve, when the hydraulic system pipe fracture, it can cut down the channel of the oil to stop the falling.
Temperature protection, when the temperature of the hydraulic oil is substandard, the machine will stop working until the temperature reverts to the safe standard.
The lower operating cost:
Low failure rate, progressive and safe hydraulic system with good control made.
Low power consumption, hydraulic lift move down depend on the deadweight to gain energy conservation.
Parameters:
We accept any custom-made specification, hereinafter the parameter only for reference.
Model Load Platform size Lifting height No-working height Dimension Power
LRL 3-2.4 3T 2.0*2.0M 2.4M 630 MM 2.0*2.0*0.63M 2.2 KW/380V
LRL 3-2.4 3T 2.0*2.0M 2.4M 660 MM 2.0*2.0*0.66M 4 KW/380V
LRL 2-5 2T 2.1*1.2M 5.0M 870 MM 2.1*1.2*0.87M 4 KW/380V
LRL 1-4.5 1T 2.1*1.5M 4.5M 800 MM 2.1*1.5*0.80M 3 KW/380V
LRL 5-6.5 5T 2.2*1.6M 6.5M 1280 MM 2.2*1.6*1.28M 5.5 KW/380V
LRL 3-6.5 3T 2.2*1.9M 6.5M 1520 MM 2.2*1.9*1.52M 5.5 KW/380V
Professional sales elevator, this is just a company presentation of a product. If you want to know other kinds lift, please visit WWW. Mornlift. Com or contact my mailbox lifttables@yahoo.cn welcome your arrival.
