603,373 active members*
3,858 visitors online*
Results 1 to 6 of 6
    Apr 2011
    13
    huanyang inverter burn
    i i have an vfd huanyang 2.2kw and today to resistors burn.
    i´m wonder if anybody can get me a shematic of the bord or just tell me the value of the burned resistors.
    i really need to fix this.
    thanks
    May 2008
    665
    You will have to post pictures and give more info in order to get some help.
    They're maybe a couple hundreds of resistors in these VFD.
    Jeff
    Apr 2011
    13
    vfd burn
    Quote Originally Posted by jeffrey001 View Post
    Jeff
    thanks , ok just can you tell me how can i check if the spindle is with shortcuts or not?
    24260
    First power the VFD up with no motor connected and see what error is shown, if any.
    Al.
    Albert E.
    Apr 2011
    13
    hi there,
    when power up the vfd no errors. when i press run with no motor connected,
    everything goog , but when i press run with the motor connected
    vfd shows me E.OC.A error.
    i´ve already tried to solder the 2 burned resistors but the burn again...
    and i dont know if the motor is in shortcut or if the problem is in the vfd.
    thanks
    Apr 2011
    13
    hi there again i forgot to ask if the spindle can be connected
    directly to the wall socket (220v AC)
    sorry if any words are not written goog i´m portuguese.
  1. Huanyang VFD Inverter all available Error Codes
    By Saintstone in forum Phase Converters
    Last Post: 07-08-2017, 11:26 AM
  2. Huanyang inverter
    By mdileva in forum Phase Converters
    Last Post: 06-18-2012, 03:24 PM
  3. Burn Carbide
    By gabedrummin in forum EDM Discussion General Topics
    Last Post: 11-23-2011, 09:07 PM
  4. R Shunt Burn
    By wanchai101 in forum Servo Motors / Drives
    Last Post: 03-26-2007, 04:20 PM
  5. burn
    By owhite in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-17-2005, 09:17 AM
