603,793 active members*
4,393 visitors online*
    May 2011
    65
    replacing motors
    Hi, I built a desktop router a few years ago, using mach 3 with electrical kit from Daves site. My stepper motors are only 125 oz in nema 23, I am going to do some cutting on aluminum plate up to 1/4" ( in increments ) expect I will need bigger motors, if I go to the largest ones listed on Daves website, do I have to change anything else electrictly speaking.
    Thanks for any help you can offer.
    Terry
    Regards, Terry Howson
    Jul 2012
    re-replacement motors
    If i was you i would check what power supply you have and the encoder drivers to see if they need upgrading, alternatively if you can't decide, settle for a "package" power supply, encoders drivers and stepper motors, you may find it could work out cheaper as a package. I would also consider if you are thinking of buying a new spindle motor check your "Z" depth and gantry stability with a bigger spindle motor attached. one other point buy a "aircraft grade" aluminium as you need a aluminium which "chips" this does'nt clog the cutter. hope this helps
    May 2011
    65
    Thanks for the reply, I appreciate the help.
    Terry
  1. Replacing Prototrak M3 with .....
    By AndrewEvans in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-14-2011, 07:28 PM
  2. replacing my hardrive
    By turbothis in forum Dolphin CAD/CAM
    Last Post: 02-21-2011, 09:16 PM
  3. Replacing Step Motors
    By Jetleg-Jazzman in forum CNC Machining Centers
    Last Post: 09-11-2009, 08:58 PM
  4. replacing wiring
    By nickmII in forum Tree
    Last Post: 02-10-2009, 06:39 AM
  5. Replacing a 9inch CRT
    By brianCAD2 in forum Fanuc
    Last Post: 12-17-2007, 10:15 PM
