586,113 active members*
3,515 visitors online*
Results 1 to 6 of 6
    Jul 2012
    Hitachi Seiki Multi HT20SII RS232 issue
    I have a 1991 HT20SII with the Yasnac LX3 seikos multi control
    It had been receiving NC programs via RS232 port but yesterday it will only send the program and no longer receives. I tested the cable and computer by sending to another machine and it is working fine, I can receive a program from the machine but it just blinks receiving data never ending or giving an error? what can I do from here? located in AZ Thanks
    Dec 2009
    539
    Have you double checked to make sure the settings on the machine side have not accidentally changed? Also take a look at the RS232 port on the machine itself. The socket/female pins on the port are easily pushed out of the back of the plug, and it seems to me you are only missing the Ready to Receive or RX signal.
    Jul 2012
    seiki RS232
    Yes, I removed the machine's socket from the panel and checked with a meter that there was contact from cable plug to back side of each pin.
    The machine settings appear to be correct I tried different settings to see if things changed but no change. The fact I can receive makes me believe the settings are correct (same for both input output).
    I don’t know where the communication cable interfaces with the main board inside the cabinet if I knew I would check there but to many plugs and cables routed through the same area to guess.
    Dec 2009
    539
    As far as I can remember, the RS232 port connects to the motherboard in the control rack - JANCD-MB22 @ CN6. Might want to test that cable for continuity. I have attached a diagram of the connection. Let me know how it turns out,
    John
    Jul 2012
    Yasnac LX3 Siecos Rs232 issue
    Thanks John for your response.
    Over this weekend I found the PDF for the LX3 Which has the same image you sent (thanks). This morning I fixed or found a way around the issue. I repined CN6 Honda connector to use port #2 instead of port #1 then changed parameters #6003 (for port 2) then changed parameters #6027,#6029 for my baud rate and it works!! I am using the same cable, connector etc. the problem is in the actual mother board I believe. Just thrilled to be back up and running.
    Feb 2017
    Re: Yasnac LX3 Siecos Rs232 issue
    I have similar problems my friend. Please give me any help!!
  1. Hitachi ht20sii opinions please
    By Deano7/11 in forum Hitachi Seikis
    Last Post: 04-16-2014, 11:57 PM
  2. Hitachi Seiki VM50 Seicos Lambda- memory issue
    By robert0707 in forum Mori Seiki Mills
    Last Post: 01-25-2011, 07:44 PM
  3. Hitachi Seiki HT20SII Chuck clamping cylinder
    By j_love in forum Mori Seiki lathes
    Last Post: 10-08-2010, 09:13 AM
  4. Hitachi Seiki HT20SII CNC Lathe
    By mroy0404 in forum DNC Problems and Solutions
    Last Post: 05-25-2010, 02:03 PM
  5. Hitachi Seiki CS 40 Lathe issue
    By mcintys in forum Uncategorised MetalWorking Machines
    Last Post: 07-02-2009, 05:10 PM
