586,108 active members*
3,175 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > default depths not changing
    Dec 2004
    75
    i am wondering why that I always have to manually enter the depth that i am drilling/milling/tapping/facing- everything when entering the parameters of these tools even though i have the depth of these surfaces correct on my model. why does it not know that when i select the geometry of a hole that is 1" deep that it is supposed to machine to that depth? (no matter where i select the geometry) it ALWAYS defaults to .5" deep. this is one of many many similiar problems i keep running in to ( clearance plane always defaults to .1 no matter hat i change it to in the settings etc etc)
    just seems that i am not really saving much time when i have to enter everything 2-3-4 times
    Dec 2011
    361
    Depth in V24 is defined by the user individually. This has changed in V25 in that when selecting hole geometry, it will be defined by the location of the machine setup to the bottom of the hole.
    Dec 2004
    75
    Thanks- I was afraid Someone was going to say something like that... of course they don't want to spend the money here since we just got v24 less than a year ago but what you are saying is even in V25, if you have a 3D model and select a hole that is 1" deep, you still have to enter the depth at a later time?
    Dec 2011
    361
    No. In V25 we have something that is called machine setups, which are the origin of the part. You can select the bottom of the hole or pocket and it will pick up depth from the point where the machine setup is configured.
  1. Changing the default post processor...
    By DavidMc0 in forum BobCad-Cam
    Last Post: 06-04-2015, 08:15 AM
  2. Different depths w/ Ace Convertor
    By blue_steel in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-24-2012, 11:16 PM
  3. Sinumerik 810M changing default settings
    By ignace in forum SIEMENS -> GENERAL
    Last Post: 10-07-2010, 05:18 PM
  4. Different depths w/ Ace Convertor
    Last Post: 02-28-2009, 09:07 PM
  5. Depths of cut on a lathe
    By M@T in forum Uncategorised CAM Discussion
    Last Post: 01-30-2004, 04:40 PM
