586,112 active members*
3,065 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Arduino PID Motor speed control for router
Results 1 to 17 of 17
    Jul 2007
    189
    I have been searching the web for several hours, looking at many web sites, postings here and Youtube videos and I have not found exctly what I am looking for.
    Presently, I am controlling the motor speed of my Bosch colt with a simple Harbor freight motor speed control.
    Router Speed Control
    I got rid of the soft start circuit in the Bosch and wired the motor direct to the power cord so that the motor control above could work properly. It works just fine, but you loose torque at low speeds.
    The Super-PID looks to be the perfect solution, but dropping one into the shopping cart results in a $175 charge. Ouch!
    www.SuperPID.com - Super-PID Closed-loop Router Speed Controller
    The use of a sensor on the motor shaft to provide feedback to the motor controller seems to be the only way to go to get proper motor control at low speeds and still maintain some torque.
    I would be interested in a DIY Arduino type project but have been unable to find any project sites that explain the process completely.
    I already know about this post on the forum, which was of little help. Not any build info, just pics and some program files.
    http://www.cnczone.com/forums/open_s...duino_pid.html
    Does anyone know of a Arduino (or other similar board) DIY source that actually has a BOM and good instructions with good images?
    The computer programming is not a problem and the scratch building is not a problem, I have all those skills.
    Just need some good guidance as to which parts are needed/ detailed build info.
    Mar 2009
    533
    EL34,
    For $175 all your homework is done for you, debugged and tested. When considering the total cost of your CNC it is a reasonable price to pay.
    I also have looked into building my own PID controller, but not to save $175. It would for the design challenge since electronics was my trade - retired now.
    Your hardware is basically your "brains" (arduino, micro, whatever...) via an optocoupler to a 15A triac phase control circuit. Another opto sensor for detecting the painted router shaft. From there it is mostly software of your favourite PID algorithm.
    No, I don't have a detailed parts list for you. Just the concepts. This project can be educational to explore....
    Jul 2007
    189
    yeah, I came to that realization yesterday after about 4+ hours of scanning the web
    I bit the bullet and ordered the Super-PID for $175
    I really didn't need anything that fancy. I was thinking I could find a simple circuit that could read a hall effect sensor and adjust the triac output to the motor.
    It wouldn't have a display, but it would self govern the motor speed.
    Oh well, I got the mac daddy Super-PID coming which is way better than what I was looking to do.
    Jul 2003
    168
    Advice on removing the Bosch Colt speed control?
    EL,
    I realize I'm responding months' late, but could you post particulars about how you removed the speed control from the Colt?
    How'd the install of the Super go? Got any pictures you can share? How do you like it? How's the noise level? And the low-speed torque?
    Thanks/.
    cnczane
    Dan
    Jul 2007
    189
    I don't have any pics of how I removed the colt speed control but, it is simple.
    Remove the top cap with the single screw and have a look.
    You can pull the speed control out of it's mounting slots.
    A wire comes in from the power cord and a wire leaves and goes to the motor windings.
    All you do is remove the speed control and join those two wires together.
    As to the Super PID, it is really nice.
    Noise level is greatly reduced because I can now use 15k and lower motor speeds which makes a huge noise difference.
    I don't really need ear protection with the lower speeds.
    Torque is great because the speed control feeds the motor when under a heavy load.
    To mount the sensor, I drilled an off center hole in the end cap.
    I painted the end of the spindle half black and half white
    You can see in my pic below that I soldered together a small brass tube and a brass mounting plate
    I slide the sensor down the tube and used some RTV silicon to seal the tube and hold the sensor in place.
    I machined the PID box out of black HDPE and made a lexan face plate
    Here's some pics
    Attached Thumbnails Attached Thumbnails Img_7055_small.jpg   Img_7181_small.jpg   Img_7182_small.jpg
    Jul 2003
    168
    Now THAT is service!
    (CNCZONE posters take note: EL34 stands thoughtfully by the keyboard, poised--I say POISED--to answer my questions INSTANTLY!)
    Seriously, EL, thanks very much for the pictures and the explanation. Your top-mount bracket idea takes all the guesswork out of "where to put the tiny hole" because I can just drill a HUGE hole and slosh the sensor around until I find the shaft! +CREDS!!
    Archaeologists stumbling on my Bosch Colt and the Super-PID nearby, still pristine in its shipping box from Down Under, will have their Clue, thanks to you.
    My speed control (pic attchd) has three wires coming from it, so I have to leave one disconnected: I'm'a guess the white. (blue is power in from the switch; THICK yellow out of the board is series wired to THIN black, which I take to be a coil; THIN white out I take to be the other side of the same coil but waddoIknow?)
    The schematic (attchd) which Al-the-Man posted elsewise for a Bosch 1617 I also believe holds a crucial hint, even though the power switch is in the line heading to a motor coil instead of to the speed control board, as it is in the Colt. I'm going to puzzle over both and come up with an idea.
    After my nap.
    Thanks for taking time.
    cnczane
    Attached Thumbnails Attached Thumbnails SpeedControlBoard_mine.jpg   Bosch_1617_circuit mods.jpg
    Dan
    Jul 2007
    189
    LOL, I work at or near the computer all day long.
    Maybe my memory is bad on how I removed my speed controller
    I tried to find the removed part but no good so I took the end cap off to see exactly what I had done.
    See the diagram for how I have mine wired
    Note that I also unhooked the Switch and Soldered/heat shrinked my connections to get the best connections possible.
    The switch is a weak point and I don't need it with the Super PID.
    I left the disconnected switch in the case to block dust from entering the switch hole
    Also note that I removed the stock power cord and used some very flexible 18 Gauge cord from the Super PID to the Bosch Colt. My power cord is Red and Black in the photo below.
    I painted the shat black first with some high temp spray paint and then used some white model paint to paint half the shaft white
    I also had to enlarge the blue plastic housing with a dremel tool to be able to see the end of the shaft.
    You have to remove the brushes first and then pull the router apart to be able to enlarge the rear shaft hole properly
    There area a couple wiggle washers on the end of the shaft, so make sure you reach up there with a pick and get them out before you enlarge the hole.
    Jul 2003
    168
    A Nother Great Idea!
    Replacing the power cord (and I recognize instantly why you did it! to reduce any tendency to bind up as you go back-and-forth). Nice.
    Even as I asked the question, I suspected you might reach for the screwdriver to take the cap off. (I was rooting for your memory...)
    I'll stare at it again this evening, but my own memory is that there are two wires to the brush. No. That has to be wrong because the current goes THROUGH the brush to the Commutator. I mean if it were true that two wires carried current to and from the brush, it would be useless as a brush.
    Anyhowway, there should be enough pix in this thread alone for Mother to figure it out for me.
    Thanks for all your services to mankind. (Hey. I'm mankind.)
    CZ
    Dan
    Jul 2003
    168
    It Hit Me.
    I stopped staring at the controller, in Al-the-Man's schematic, and noticed there's only one way for current to get through both the motor's coils with just two wires.
    After I connect it in the only sensible way, exc. for the switch (which I want to keep to avoid that "brown-pants" surprise when the Super-PID turns on the router), Al's schematic looks like yours.
    "Yeah, that oughta work."
    Attached Thumbnails Attached Thumbnails Motor_and_Supply.png   Motor_and_Supply_2wires.png
    Dan
    Jul 2007
    189
    Yes, my black and white diagrm is absolutely correct.
    I was staring at my router wires when I sketched it out.
    If you want to keep your switch, just interrupt the black wire as it goes from the power cord inlet to the coil.
    That's on the right side of my diagram.
    But, the switch is a weak spot cause it has the wimpy little screw terminals and I doubt the contact points are as beefy as they should be for the large current that the motor can draw under full load.
    I replaced the power cord cause it's 12 feet long and way too bulky.
    All I needed was about 3ft of 2 conductor wire that was flexible and di not get in the way.
    Also, the PID has screw terminal blocks for the Ac to the motor.
    It just makes sense to ditch the big bulky power cord and run a nice clean and short dual conductor wire to the motor.
    I have had the original Bosch power cord trip limit switches on my Y axis several times in the past and that sucks
    Jul 2003
    168
    Okay, I didn't see that one coming: the floppy power cord banging a limit switch...
    OTOH, I coiled up the power cord into a bundle, and I just have Super-PID control the outlet it's plugged into, which rides along on top of my Z axis.
    I had the idea that someday I might need to quick yank it off and I'd at least get the full-speed. I have to admit that I have not thought about, until just now, the fact that I will need to coil up the long sensor cord if I ever do it (it terminates in a Conxall fitting so I wouldn't have to lug the Super-PID box along at least).
    Cheers, EL! Good helps for me.
    Dan
    Jul 2007
    189
    Good luck with your machine
    Jul 2007
    189
    I added a new web page page on how I set up my Super PID
    It also has the Bosch colt wiring diagram that I drew
    Hopefully it will be helpfull to others
    EL4's CNC projects Main page
    Jul 2003
    168
    I should mention here that I did get the control out of the machine. It was duck soup (for the international readers that means it was a Marx Bros. movie. No, that was a joke. It means it could only have been simpler if it had printed instructions inside the cap.)
    Anyway I did it over there:
    http://www.cnczone.com/forums/1203390-post1958.html
    and referred back to here which is probably going to bring down the internet with a topic-loop when I hit "submit."
    EL34?
    If it comes back up, could you elaborate about how you drilled your hole straight down over the top bearing? I was expecting that plastic was a cap that unclipped or something, but it seems to be an integral part of the housing--and rumor has it may even be holding the upper bearing itself. (I was about to snip it off and maybe epoxy it back if necessary, but then my reason say, "you could aks EL34 BEFORE you ruin it.") If the internet stays down (first, "sorry") I'm going to explore with a spade bit. I figure if I hit the shaft, only harm is to the spade's point. Then I can widen the hole with a metal bit or even an X-acto (TM) knife.
    Thanks. I have to say I do like another idea of running it in alongside the power cord just for the sake of great strain relief, and dealing with only one cord.
    Dan
    Jul 2007
    189
    That whole top plastic area is a bearing support
    Do not clip it off.
    I explained what I did on my web page
    here's the main page link
    then go to the Super PID page
    Jul 2003
    168
    Red face
    Quote Originally Posted by EL34 View Post
    Do not clip it off.
    Saved by abject laziness. Again.
    Well, beFORE when I went there, I just read the pictures...
    Dan
    Jul 2007
    189
    I keep adding more info to my CNC pages as I rememer different things and when I dig through my pictures collection.
    It was a while ago that I did the Super PID router conversion, but a bunch of it came back to me when I looked inside the router
  1. open source Atmel/arduino PID motor control
    By mrendu43 in forum Open Source Controller Boards
    Last Post: 08-09-2019, 03:09 PM
  2. Router Speed Control
    By Seamazter in forum CNC Machine Related Electronics
    Last Post: 10-27-2010, 08:47 PM
  3. Router speed control
    By tanky321 in forum DIY CNC Router Table Machines
    Last Post: 03-30-2008, 06:34 PM
  4. Router speed control
    By dwacker in forum DIY CNC Router Table Machines
    Last Post: 05-21-2007, 08:10 PM
  5. Router speed control
    By ljoe1969 in forum CNC Machine Related Electronics
    Last Post: 08-01-2005, 02:13 PM
