I received my Sherline 2010 mill and 4410 lathe package back in April (2012) but apart from some testing I haven't been able to get the mill to work. I suppose I have the same issue with the lathe but I have put that aside until I resolve the problem with the mill.
The package came with the 8760 controller, a new Dell Optiplex 390+, Windows 7 and Mach 3 demo.I purchased the Mach 3 licence from Artsoft and I am using all legit versions of CAD/CAM software packages....so no funny stuff here.
These are the problems I encountered:
a) initially mill seemed to run correctly but after a while the Z went 'minus' all the time. Didn't matter if the Gcode called for Z+....it went Z- I am talking about the physical machine movement here, the Mach3 screen showed the correct direction
b) next and all subsequent tests showed the same issue with X, Y and A... one direction only
c) with the help of David of discountcampus.com (from whom I bought the Sherline) we tried all kinds of ports/pins and configuration settings without any positive results. With approval of Sherline, the controller box was sent back to California and a new or repaired box was returned to me. Cost me US$ over 200 in shipping unit back then paying the duties, taxes and customs brokerage on replacement. Still the same problem. Axes moved in one direction only.
d) Again, with the approval of Sherline I sent the 8760 board only (not the entire box) and a replacement was shipped shortly afterwards.....no change...same problem..
e) David offered to send me an extended controller box on loan CNC Extended Box + Switches Includes Extended Box + Switches + all needed cables. to see if his theory is correct. He suspected that the 'extended' box would rectify the lower/weaker quality of newer manufactured parallel port signals. This 'weaker signals/newer machines' made me think about an 6 year 'unrefined'/generic old computer I had sitting around. I loaded Mach3, hooked it up AND IT WORKED so I didn't take David up on his offer.
Unfortunately the old computer's motherboard gave up he ghost . I had an other old computer but this one did not make a difference. Same problem with the axes directions. I then went and bought a PCI parallel port card for the old computer. Same problem X,Y,A move only PLUS and Z only MINUS but as before, the Mach screen shows correct direction.
As to electrical supply, we have 110/220V 50Hz here but I have 2 other CNC machines working perfectly. One is a little DSP controlled 400mm x 400mm x 100mm and the other is a big, Syntec controlled 1524mm x 3048mm x 200mm and they work without issues. The only problem I have is with the Sherline.
I am sure David and I will again spend time on the phone during the coming week but I wonder if someone on this forum had the same problem and found a solution to share.
Any suggestion(s) would be welcome.
