586,113 active members*
3,540 visitors online*
    Oct 2011
    Programming on a Yasnac i80m
    Here at work and displeased with mastercams 2000 lines of code for a profile, I decided to whip up a macro (which is about 990% shorter) to do the job
    Worked out all the math, all the equations, checked with the yasnac macro specs, made the program, loaded it into the machine, tried to run and I get alarm 0103 illegal character
    I cannot seem to use any of the #[]+* keys in a program without throwing this alarm. I cant even set a variable from mdi because it throws the alarm..
    I cannot figure out a way and sifting through my manuals has provided no insight other than the paramter values for EIA/ISO the chars apply to.. all were set to 0 from pm4100 and on (corresponding to the chars) so I tried changing them to 1 with no dice.
    For now I went through the process of calculating each point, thankfully I only had 20 points for 40 calculations, and thanks to new age calculators I didnt have to input the equation each time just modify the vars.. but still I was quite excited to put a macro to work :/
    Any ideas guys?
    Sep 2010
    1230
    Quote Originally Posted by SirDenisNayland View Post
    Any ideas guys?
    The error you have is typical of a control that doesn't have the User MAcro Option. Are you able to display a Macro Variable Page?
    Regards,
    Bill
    Oct 2011
    I did look for a variables page but was unable to locate one, or how to get to it in the manuals.
    That was one of my fears. I guess its not a huge deal but it does suck to know the machine lacks that ability.
    I know there are four different option packages which unlock greater numbers of vars respectively, but I had assumed it would come with at least the most basic.
    I'll have to look into the options but thanks for pretty much confirming my fears lol.
  1. Yasnac i80m Alarm Code
    By PaulRP in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-09-2020, 07:28 PM
  2. Looking for a Yasnac i80M Programmer
    By Alfonzo in forum Employment Opportunity
    Last Post: 11-27-2018, 05:43 AM
  3. Yasnac i80m no DC control circuit power
    By randyh in forum DNC Problems and Solutions
    Last Post: 09-09-2005, 09:21 PM
