586,103 active members*
3,266 visitors online*
    Oct 2005
    42
    3 phase transformer needed
    Hi All,
    does anyone know of a UK supplier who produces a 440 volt 3 phase to 220 volt 3 phase transformer, current draw is up to 15A/phase, off the shelf? It is needed to run a US built machine here in the UK.
    Thanks in Advance
    Mar 2005
    1498
    051226-1558 EST USA
    pauluk:
    You might use two single phase transformers.
    It is fairly common in the US to use only two transformers on the pole. One is larger with a center tap to provide 120 - 0 - 120 single phase circuits with the center tap grouinded. The second transformer supplies the remaining phase of the three phase circuit.
