588,074 active members*
4,653 visitors online*
IndustryArena Forum > MetalWorking Machines > Hyundai Kia > problem with the Steady rest and tailstock
Results 1 to 8 of 8
    Apr 2012
    13
    Hi there.
    We apologize for my poor English. Hyundai Kia machine is a skt 400 LMC. What is the M code to open the Steady rest? And where the machine saves the current position of tailstock and steady rest (after selecting the M83 head after the tailstock is not going where it is needed, the same in the case of steady rest. I hope that someone will understand my story and help.
    Jul 2012
    Hallo,
    try it with
    M73 : HYD. REST CLAMP
    M74 : HYD. REST UNCLAMP
    M77 : HYD. REST PIN IN
    M78 : HYD. REST PIN OUT
    if this is not correct give me a feedback and i will check it as this is from a SKT400M and this should be almost the same
    and the Tailstock Positioning parameter should be in the macro variable.
    you need to go to (Keyboard) Offset and press at the screen to the right side until you get a softkey called Macro. Now search for Macro parameter 503 (or just use page down).
    Also you can check the correct Parameter easily by checking to which position your tailstock moves and double check it with parameter 503. if this value is the same like your Machine position value, this parameter the correct one. as i´m not 100% sure.
    But in it was 100% some of the 500 parameter
    O9020(M83 T/S PIN UP)
    IF[#1008EQ1]GOTO100; (G55.0→Y4.2 (HYD.REST PIN-UP SOL ON)이면 N100으로)
    IF[#1000EQ1]GOTO10; (G54.0→Y7.0 (T/S PIN-IN SOL ON)이면 N10으로)
    #1=#4001; (G00/G01/G02/G03 SAVE)
    #2=#4006; (G20 inch / G21 metric SAVE)
    #3=#4109; (F CODE SAVE)
    G21; (INCH DATA INPUT)
    #150=#5021; (X축 현재 기계좌표)
    #151=#5022; (Z축 현재 기계좌표)
    #152=#502; (PIN-DOWN시의 X축 기계좌표) <--
    #153=#503; (PIN-DOWN시의 Z축 기계좌표) <--this one i mean
    Apr 2012
    13
    Hi
    Thank you very much for your help. I have a problem if the program inserts the speed limit "G50 S650 ', the spindle does not reach the workpiece axis of rotation only about 550th This only happens when you run the program. With MDI, no problem.
    Jun 2007
    67
    G50 S650 will limit the RPM to a max of 650 RPM so no mater what you program your G96 as the machine will only go to 650
    You need to raise the G50 limit to whatever is safe for your setup
    Best regards
    Chris
    Apr 2012
    13
    My friend does not understand, or I do not understand you.
    Why is giving the machine a restriction to 650 rpm (G50 S650), the machine accepts up to 550 rpm limit?
    Jul 2012
    I think it is because of the Gearbox.(Parameter)
    as Low gear is from 0-550 rpm (i thought 500rpm) and you are during cuttingcycle it will not switch to second gear which is from 550-3000RPM
    and as far as i know that´s why it is just possible to run up to 550rpm and not to 650rpm
    otherwise the pindle would stop, change gear and run again, and this wouldn´t be what you want, during cutting....
    hope this makes the situation more understandable
    try it when you call M3S600 and G50SXXX and this should work correctly
    Jun 2007
    67
    Good point khaot183
    Also
    Are you programing G96 or G97?
    What is the diameter being cut?
    Apr 2012
    13
    G96 is programmed, when planning the machine should reach more of the limitations and reaches about 100 less than is given. In MDI mode, everything works as it should. When programming G97 is also good.
  1. self centering steady rest
    By dynoman in forum Uncategorised MetalWorking Machines
    Last Post: 08-03-2013, 10:31 AM
  2. steady rest rollers
    By mattmazak in forum Want To Buy...Need help!
    Last Post: 01-24-2010, 01:23 PM
  3. Does anyone here use an Omnirest steady rest?
    By MadMax in forum Uncategorised MetalWorking Machines
    Last Post: 12-14-2009, 12:34 AM
  4. TL-2 Steady rest
    By rbest27 in forum Haas Lathes
    Last Post: 04-17-2008, 12:15 PM
  5. Open Steady rest
    By Loelco in forum MetalWork Discussion
    Last Post: 02-07-2008, 11:29 PM
