588,385 active members*
5,481 visitors online*
Thread: V24 scaling
    Dec 2004
    75
    V24 scaling
    All I am doing is opening a DXF file that was originally scaled 1:2. it opens but all of the dimensions have been scaled down in half... i have hundreds of these files that need work and i dont have time to manually re-scale and re-dimension each drawing. isnt there a option not to scale dxf's somewhere?
    Mar 2012
    1570
    You are working with files that are scaled 1: 2?
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
    Dec 2004
    75
    Quote Originally Posted by aldepoalo View Post
    Yes- 1:2 is what the original DXF was scaled by whomever drew it. I know there are ways to make it the way I need to see it but i really need to do as little as possible due to time constraints. is there a setting i am missing somewhere?
    Apr 2008
    1577
    Quote Originally Posted by hatchmar View Post
    Unless I am mistaken, the dxf is not really scaled. The dimensions the original author put on there are scaled.
    The best thing I can think of is to select each dimension, right click, "Entity Modify" and set the scale to 2.0. When you hit OK, the text of the dimension will be over-ridden.
    Yes, it will be one at a time.
    There might be a quicker way but I don't know if it will "fix" the file permanently. It might only update the dimensions temporarily so you can print it off. Do you have a file you could share? It may save you a ton of time.
    Mar 2012
    1570
    Can you attached a sample DXF file?
    What I am thinking is the part is scaled 1 : 2, so in other words it's not drawn to scale 1 : 1. So if you open this file you will have to scale it to size in order to use the geometry to program with.
    You are asking is there a way to auto scale up or down drawing you work with?
    Al DePoalo
  1. scaling
    By davidperry3 in forum Uncategorised CAD Discussion
    Last Post: 02-16-2012, 05:56 PM
  2. Scaling
    By caddisfly in forum Haas Mills
    Last Post: 05-27-2011, 05:25 PM
  3. G51 Scaling: how to?
    By Donkey Hotey in forum Haas Mills
    Last Post: 06-07-2010, 04:08 AM
  4. scaling
    By reedmiles in forum Haas Mills
    Last Post: 02-28-2008, 04:11 PM
  5. scaling?
    By BiggerHammer in forum Hobby Discussion
    Last Post: 02-20-2008, 04:40 PM
