588,548 active members*
5,958 visitors online*
    Sep 2008
    16
    Meldas M50 ..I put the backup???
    Hello
    I have a problem, i put the my backup of PLC program and now i can't look to the ladder, it have only the lines of outside. What i need to do to solve that?
    Best regards
    Vide
    24221
    Sounds like nothing went in?
    Al.
    Albert E.
    Sep 2008
    16
    Machine work
    Hello
    The plc progra is there becouse the machine work, but i can't change the software limit's of Z, i can change with the plc in stop, when i put in run, the p2013 of z change to -410 alown.
    I wont look to ladder to saw were is it.
    Best regards
    Vide
    Jan 2011
    What caused you to reload the PLC from backup?
    Did you loose SRAM and settings?
    Axis stroke limits generally are set in the parameters, both user and Machine
    Under user parameters look for the ones labeled "OT-CHECK-N" and
    OT-CHECK-P under the User params - AXIS
    Under the machine parameters (these are set by the OEM)
    there is OT- and OT+ under the axis group
  1. battery backup
    By Daniel Boone in forum Fadal
    Last Post: 10-03-2012, 06:17 AM
  2. Backup of TOPWELL TOP-1A MELDAS M50 1995
    By girishdk in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-10-2010, 03:34 PM
  3. Sram backup.
    By ajm100a in forum Fanuc
    Last Post: 12-18-2009, 03:12 PM
  4. Meldas 64M Backup
    By Hypnotique in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-13-2009, 05:24 PM
  5. Backup Script..
    By Rekd in forum Mastercam
    Last Post: 09-11-2003, 03:34 PM
