587,307 active members*
3,716 visitors online*
Thread: Fog Buster
    Aug 2011
    37
    Smile Fog Buster
    Has anyone tryed the new Fog Buster Coolant Sprayers ? Thinking hard about get one.
    Mar 2009
    1863
    Quote Originally Posted by david parkhurst View Post
    I have been using them since 2004. I had a dual nozzle on each of my CNC machining centers, and I had a single nozzle on my conventional mill. And I have a dual nozzle for my PCNC1100.
    For surfacing, facing and side cutting you can't beat them, but I haven't had much luck when pocketing, drilling or tapping. It just seems at that low pressure, there just is not enough volume for thise processes.
    The company is right here in town, so I think I'll go down and pick their brain a little bit, maybe they can give me a clue.
    You can buy GOOD PARTS or you can buy CHEAP PARTS, but you can't buy GOOD CHEAP PARTS.
    Apr 2009
    14
    Fog Buster
    I have a 770 PCNC with a dual head Fogbuster and have been happy with my choice for what I do. One reason I bought a Fogbuster is I knew I would only be using the CNC intemitently for hobby use and didn't want an open tank of coolant smelling things up.
    Another thing I have found useful is that when using Carbide tools, I can turn off the coolant and just have an airblast which gets rid of the chips, saves coolant, and does not have the potental for cooling shock as can happen with flood cooling (can a 770 really push a carbide end mill that hard??).
    I do quite a bit of engraving in 2 layer plastic and found that if I turn off the Fog buster, the edges of the engraving are jagged and not cut cleanly but when I turn on the coolant it comes out nice and crisp so must be doing some good.
    One downside is that you have to make sure the nozzles are pointed at the tool tip which changes with different tools but I think that is true for most coolant systems in this league.
    Bruce
  1. Flood Cooling vs. Fog Buster
    By Ron111 in forum Benchtop Machines
    Last Post: 09-15-2018, 05:00 PM
  2. Review of Tweaked Fog Buster System installed on Tormach
    By cheetahcnc in forum Tormach Personal CNC Mill
    Last Post: 03-09-2015, 10:11 PM
