603,365 active members*
2,597 visitors online*
    Apr 2007
    144
    Mori SL25 w/ Fanuc 16T
    Our '94 Mori SL-25 w/Fanuc 16T dropped the X-axis to the lower hard limit when the operator stepped away for lunch the other day.
    No alarm other than OVERTRAVEL was indicated.
    When the OVERTRAVEL RELEASE button is held in, we can rotate the manual pulse generator and the position display counts up as if the axis is moving but there is no actual axis movement.
    Initially I thought that the motor-to-ballscrew coupling had loosened up but when I checked it there was no motor rotation when I was watching as someone rotated the MPG.
    The Z-axis has the same behavior. (i.e. the position display counts up but no actual movement.)
    The servo amp is A06b-6066-H244 and controls both axes.
    Any ideas? Faulty servo amp? Faulty axis card? Other?
    Any help will be appreciated.
    emexcee380
    May 2004
    4519
    Hard limit switch activated, not just soft limit?
    Feb 2009
    6028
    First, make sure machine lock and Aux lock are off. Custom button-operator panel, all should be off. If all are ok, I would guess a servo amp.
    Apr 2007
    144
    Guys,
    Thanks for the replies.
    TXCNCMAN: Yes, it's only the hard limit that's contacted. When we press the O.T. RELEASE button the machine (and servo amp) go READY and we can see position counting when the mpg is rotated. But neither the X nor Z axes physically move.
    UNDERTHETIRE: We suspect the servo amp is the culprit also. It was replaced almost exactly 30 days ago to solve a hard alarm. (Low Voltage). A (warranty) replacement unit should be here today. We'll see....
    Thanks again for your responses,
    emexcee380
  1. Parameters of MORI SIEKI SL25 B5, FANUC 10T, S/No. 695
    By ejaz199 in forum Mori Seiki lathes
    Last Post: 01-06-2025, 10:06 PM
  2. MAPPS I assistance on Mori SL25
    By fordav11 in forum Mori Seiki lathes
    Last Post: 08-25-2011, 12:12 PM
  3. MAPPS I assistance on Mori SL25
    By fordav11 in forum Fanuc
    Last Post: 08-22-2011, 08:41 AM
  4. Mori Seiki SL25
    By KaesynCAM_Tech in forum Mori Seiki lathes
    Last Post: 10-07-2008, 05:07 PM
  5. Mori SL25 ques.
    By ajl6549 in forum Community Club House
    Last Post: 10-07-2006, 04:33 PM
