587,033 active members*
3,393 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Hawk 5m wiring harness femal conector (Bloke?)
Results 1 to 2 of 2
    May 2017
    58
    Had a no so fun experience, x axis started acting funny with irradict movement in certain areas. Wiggled the harness and it went away for a bit. Few months later threw x axis error and couldnt resolve like before. Swapped x and y harness and servo started to rapid cycle back and forth. Turns out had a loose/broken wire in the harness and it took out an encoder wire in the servo/broken green wire servo smells like electrical short. Long story short checked entire x harness and repair everything but connection is still bad with zero movement with a good servo. Swaped harness again with y harness x works fine. Continuity through all of x harness is good servo amp is good. Thinking it is the pins in the 20 29s style female conection. Honda side looked fine. Question is where can I find the baldor specific 16 pin on the harness side? Anyone have a part# or ideas? Id be willing to repin it but cannot get the main power pins out. And do not know where to source new pins. I will be calling hurco and baldor tommorrow to see if they have any info. I despratley need to get back up asap. Thanks all.
    May 2017
    58
    Quote Originally Posted by Sandvet03 View Post
    Solved,plug is a ms3106e 24-7s.
  1. Wanted Hurco Hawk 30 wiring diagrams
    By locost_cam in forum HURCO
    Last Post: 08-29-2017, 01:15 PM
  2. Cincinnati Hawk TC 150 electrical wiring diagram
    By miroksp in forum Machinery Manuals / Brochures
    Last Post: 01-06-2014, 10:41 AM
  3. Hawk 150 wiring question
    By Bill Egan in forum Cincinnati CNC
    Last Post: 09-30-2010, 08:57 PM
  4. Diagram for the 25-pin conector!!!
    By yumuri in forum CNC Machine Related Electronics
    Last Post: 01-07-2010, 07:12 PM
  5. OM-A .....M5 CONECTOR
    By gabedrummin in forum Fanuc
    Last Post: 06-18-2009, 03:50 PM
