603,893 active members*
3,935 visitors online*
Results 1 to 11 of 11
    Jul 2011
    26
    Ok. I give up.
    I am pretty new to this CNC thing, but I had no problems designing and building a 3 axis machine. The problem I have is that I cannot figure out is how to let Mach 3 know where the table ends! I've tested the limit (home) switches and they all work, but I just cannot figure out this part of the software. Is there anyone out there with a setup guide easy enough that a 6 year old can understand? (I am 46).
    The controller is an EZ CNC.
    Gustavo
    Dec 2011
    161
    Why you need mach to know where your table ends?
    Jul 2011
    26
    That's my point. I can't figure out how to configure mach so it doesn't keep on hitting the limit switches.
    Apr 2004
    5951
    Why does it keep on hitting the limit switches? Is it running out of control, or are you trying to make parts that are too big for your machine? Have you tried setting soft limits that are inside the limit switch extremes? Have you read section 4.5 of the Mach manual, http://www.machsupport.com/docs/Mach...all_Config.pdf which talks about the various ways you can hook up limit and home switches?
    Andrew Werby
    www.computersculpture.com
    Dec 2011
    161
    Awerby's right, first set the soft limits, then make shure your job envelope does not exceed your machine limits.
    35494
    Watch the "Homing, Limits and Offsets" video here.
    1943
    I realize the OP posted in the Mach forum, but he said in post #1 that the controller he is using is EZ CNC, not Mach.
    http://www.accesswave.ca/~blandry/ezcnc/abimp.html
    Dec 2011
    161
    Quote Originally Posted by 109jb View Post
    E Z CNC is an old software
    Read again.
    Cheers
    Jul 2011
    26
    I'm sorry I am confusing the heck out of everyone, I am getting more senile than I than I thought. The stepper controller is HobbyCNC EZ driver board, and I am using Mach3.
    Last night I watched the tutorial videos on soft limits but I'm still confused. Do the values entered as the soft max and min max are equal to the table dimensions?
    Again, sorry for the confusion.
    Jun 2007
    3738
    Cool Use the KISS METHOD!!
    They can be any number you like, as long as the range is the length of the travel or less.
    You need to setup where the end of travel is relative to the homing switch.
    It is all in the manual.
    Keep It Simple Stupid
    Jul 2011
    26
    NeilW20, thank you. That did the trick. It was so easy that I looked for the most complicated solutions.
  1. please give some advice.
    By MALOY718 in forum Controller & Computer Solutions
    Last Post: 06-14-2011, 05:32 PM
  2. i give up NEED HELP
    By tjd10684 in forum Mach Mill
    Last Post: 01-29-2011, 06:03 PM
  3. Give me G-gode!
    By Guldberg in forum PTC Pro/Manufacture
    Last Post: 05-29-2007, 12:32 AM
  4. Can anyone give me some input
    By Trexler Signs in forum Uncategorised CAM Discussion
    Last Post: 08-22-2006, 05:37 PM
