586,055 active members*
4,424 visitors online*
IndustryArena Forum > MetalWorking Machines > Hardinge Lathes > Conquest almost working - no hydraulic pressure
Results 1 to 6 of 6
    Apr 2006
    19
    We got our 1990 Conquest 42 in place and powered.
    I am having a power up problem with the hydraulic motor.
    It doesn't come on when I turn the machine on.
    I get a "not ready" alarm that I can't reset and some other alarms related to no hyd pressure.
    Does anyone know if there is a RESET or breaker or fuse or something that could have tripped?
    It was working at the machine dealer a couple of days ago.
    Thanks for any hints,
    Robert
    Aug 2011
    79
    Hello Robert, I don't know any specifics about your machine. So I can't tell you anything specific only things in general, but from the info that you have given there are several things that you may want to consider. You said that you are getting several faults. That suggest that you have some type of computer controling the machine. That means that you most likely have machine software that controls the hydraulics. You also said that it worked at the dealer several days ago. I would suggest several things. 1. Check that you have enough hydraulics fluid. ( since it was recently moved the HYD. fluid might have been drained) 2. I would check that your phasing for your 3 phase motor is correct ( Wires were disconnected and reconnected, is the phasing the same?). 3rd. I would call the company that bought you the machine from. Perhaps they could give you some more specific suggestions. 4. Who hooked up the machine for you? What were they responsible for? Talk to them. 5. Do you have an electrician who can check for power, circuit breakers, blown fuses, tripped overloads and tripped breakers? 6. Are you starting the machine correctly (in the right sequence). After that I would check if the other faults that you are getting are giving you some type of clues. Good Luck FanFan
    Apr 2006
    19
    Hi FanFan,
    Thank you for the response!
    I have been working on it all day.
    I have the hydraulic issue sorted out as well as all alarms and other functions.
    Today was figuring out how to move everything manually.
    This included Tailstock, Zero Return, Turret indexing, Parts catcher, Tool setter, Chip conveyor, and Spindle control.
    Making my way down the learning curve!
    Robert
    Sep 2019
    10
    Hi I have Hardinge conquest t42 and fiew issues with that mavhine.
    1. Low hyd system pressure. I put new hydraulic oil.
    2. Codes m3 and m4 , m13 and m14 dont work
    spindle run only on code m23 !!! Please help. Can you have some basic program sample?
    Sep 2019
    10
    Aug 2011
    79
    Re: Conquest almost working - no hydraulic pressure
    Hello, As I mentioned before I am not familiar with Hardinge machines but maybe I can point you in the right direction. First, what kind of control do you have on your machine? Fanuc? Second is this a new machine to you or has the machine been running in your shop for some time? Did the problem start with a hyd. problem. Do you have a manual mode? Can you jog or turn the spindle in manual? As far as program code I am not that good at it. But I might try a M05, S200 and then a M03. and then try another M05 to turn the spindle off. You also might have to do a gear change. Does everything else work? Does the machine home out? Can you turn the coolant on and off? Do all the axis move? Do you have a turret? Does it rotate? Any messages on the crt? I wish you luck.
  1. SL20 Hydraulic pressure alarm???
    By gixxergary in forum Haas Lathes
    Last Post: 11-02-2017, 12:47 AM
  2. VQC 15/40 NMI 201 Low Hydraulic pressure
    By Super Chicken in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-18-2012, 09:10 PM
  3. hardinge conquest T51 hydraulics not working
    By ajprecision in forum Maintenance DIY Discussion
    Last Post: 03-12-2012, 10:18 AM
  4. Conquest T-42 Hydraulic
    By imac in forum Hardinge Lathes
    Last Post: 04-27-2010, 09:04 PM
  5. 1040 Low Hydraulic Pressure
    By pinguS in forum Fanuc
    Last Post: 06-18-2007, 02:53 PM
