587,065 active members*
3,881 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > What should I keep here? - Mach3 retrofit
    Nov 2010
    I am working on doing a Mach3 retrofit on an old Hurco KMB1X mill. I have most everything worked out on the servo drive side, but am kind of lost on what to do on the side of the cabinet with the spindle control stuff.
    What should I try to salvage in the attached picture? All I had planned on keeping in there was the main disconnect. Would a new spindle controller replace most of this, and if that is advisable then could someone recommend a good one? Sorry for the lack of knowledge on this, I have mainly worked with smaller (newer) machines.
    Thanks!
    am
    Nov 2010
    Just realized that my photo hadn't attached when I first posted. It is there now.
    am
    Feb 2009
    6028
    Dump it all! Newer vfd will take up very little space. Hitachi, fuji, baldor, yaskawa are all good as are others. Even the huywang or how ever it's spelled seems ok so far.
    Nov 2010
    Quote Originally Posted by underthetire View Post
    That is what I was hoping to hear. Does anyone have a recommended supplier? I am having issues trying to figure out exactly what specs I need. I attached the specs off the motor. I do have 3 phase power at the machine
    am
  1. Mach3 retrofit, looking to hire, NJ 07631
    By trendmfg in forum Mach Mill
    Last Post: 02-29-2012, 03:21 AM
  2. Hurco Mb1/Mach3 retrofit
    By SilvioB in forum HURCO
    Last Post: 02-17-2010, 05:41 PM
  3. Sieg SX3 6000rpm retrofit kit for mach3
    By slektning in forum Benchtop Machines
    Last Post: 01-28-2010, 06:08 AM
  4. Retrofit dynamyte 4400 to mach3
    By toomuch in forum Uncategorised MetalWorking Machines
    Last Post: 10-25-2009, 11:37 AM
  5. Hurco KMB-1 Mach3 Retrofit
    By jalessi in forum HURCO
    Last Post: 08-19-2008, 03:19 PM
