586,082 active members*
3,658 visitors online*
    Aug 2012
    Need to install Linux?
    Well guys I have to just install Linux Operating System on my PC.. the thing I would like to know is that, Is there requirement of any additional hardware for installing hardware and after Linux, is there be any problem to run Printer and scanner?
    Apr 2010
    42
    Try to use the most easy linux for cnc . Linuxcnc from the LinuxCNC.org.
    It is a Ubuntu 10.04 LTS (long term suppert) with the RTAI patched kernel, needed to run the linuxcnc (EMC2) stepper control.
    There is a lot of supported hardware and software. The linux world is big, only closed mind people look out of a window but not out of a barn door.
    Aug 2012
    Well you mean to say that i should not use Linux but only windows...???
    Anyways going to check out the link provided by you for the right job regarding Linux, thanks.
  1. Un-install & re-install changes Mach3
    By Beefy in forum Mach Software (ArtSoft software)
    Last Post: 08-01-2012, 09:01 AM
  2. CAD and CAM for linux ?
    By bianchi in forum LinuxCNC (formerly EMC2)
    Last Post: 07-16-2012, 10:40 PM
  3. 40W under linux
    By atarkri in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-22-2011, 06:21 PM
  4. Linux - EMC2
    By Vegabond in forum Norwegian
    Last Post: 07-06-2009, 07:49 PM
  5. BDI Linux
    By ynneb in forum LinuxCNC (formerly EMC2)
    Last Post: 08-03-2004, 10:38 PM
