603,870 active members*
7,054 visitors online*
Results 1 to 7 of 7
    Sep 2012
    Vacuum hold down
    I need help with what type of vacuum hold down to do. I only do lines of text on pine material that is always 4" wide. I never do cut out stuff. So I want to set up fixtures on the table where the pine slides into, then just have a few holes underneath the material to hold the pine in place. Can anyone tell me what type/size vacuum pump I need?
    May 2004
    4519
    Why are you wanting to go to the expense and trouble of vacuum work holding? Mechanical work holding (clamping) should work quite well for what you described. There are many options for edge clamping you can look into.
    Jan 2006
    2985
    even de-sta-co clamps might work alright as long as you have a portion of the wood that isn't being engraved.
    Matt
    Sep 2012
    Speed is what I'm after. I'm doing large volume manufacturing. We have a pretty slick mechanical method, but I'm looking to trim more time. I am interested though in seeing other styles/types of mechanical hold down. Can you post a link?
    May 2004
    4519
    Sep 2012
    Thanks a lot for the links. Does anyone out there have ideas on vacuum hold down?
    May 2004
    4519
    Make yourself a vacuum fixture using pourable polyurethane rubber over a plywood plenum. Drill holes at appropriate locations into the plenum. This makes like a huge suction cup you can mount at any location on the table. Then attach it to an appropriate vacuum system and you are ready to go.
  1. Vacuum Hold down for wood.
    By HomeCNC in forum DIY CNC Router Table Machines
    Last Post: 06-08-2014, 03:29 PM
  2. Vacuum Hold down?
    By wendtmk in forum Work Fixtures / Hold-Down Solutions
    Last Post: 02-23-2010, 04:02 PM
  3. Do i need a Vacuum Hold System
    By rcs1010 in forum DIY CNC Router Table Machines
    Last Post: 05-13-2008, 06:39 AM
  4. hold down vacuum system
    By alfonsonog in forum DIY CNC Router Table Machines
    Last Post: 02-10-2008, 08:11 PM
  5. 4x8 Vacuum Hold Down
    By elogicca in forum DIY CNC Router Table Machines
    Last Post: 07-24-2007, 02:06 AM
