587,997 active members*
1,926 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > How to set up Servo Amplifier Module in Fanuc 16i-M system
    Aug 2012
    4
    Hi, there! We have one Fanuc 16i-M system:
    PSM: A06B-6087-H1130 (35KW)
    SPM: A06B-6078-H211#H500 (rated output current 48A)
    SVM: A06B-6096-H105, ver. C.(rated output current L axis 18.7A)
    Spindle Motor: A06B-0855 -B100#3000 (S1 A~ Max 44; S2 A~ 56).
    They work well.
    We changed the SVM to another one (the same part no., different ver.): A06B-6096-H105, ver. E. But when we enabled it, just "-" was displayed.
    Could somebody tell me how to figure it out?
    Thanks a lot.
    Mar 2005
    816
    I have a 18i M Model A. Has pretty much the same basic part numbers you listed. Do you have the amplifier manuals?
    I'm not too familiar with those PSMs.
    I've never tried the 6096's. But I have used several of the 607x and 608x type SVMs and am still setting up my 18iMA ; havent chosen a spindle servo or axes servos yet, so I don't know which to choose. I believe my Axes DIMMs are serial. Someone would have to tell me.
    I can send the manual if you don't have them.
    I'll look up the - error.
    Mar 2005
    816
    The "-" means that the drive is not enabled. Do the other drives comes up OK? You will see a "0" when they are enabled. Also, why was the drive replaced?
    Aug 2012
    4
    Thanks a lot, my friends. That unit is used, so we want to test it.
    Thanks again!
  1. ABNORMAL CURRENT Fanuc Servo Amplifier
    By Robyr in forum Servo Motors / Drives
    Last Post: 10-06-2013, 05:48 PM
  2. Fanuc servo amplifier
    By hotrob1 in forum Fanuc
    Last Post: 04-27-2012, 01:58 AM
  3. Fanuc Servo Amplifier Fault
    By turbo jim in forum Uncategorised MetalWorking Machines
    Last Post: 05-16-2011, 08:30 AM
  4. Fanuc servo amplifier alarm
    By KENGLIAN in forum Fanuc
    Last Post: 02-19-2011, 03:37 AM
  5. Servo Amplifier FANUC
    By Antonio Arguijo in forum Fanuc
    Last Post: 12-07-2010, 03:53 AM
