603,344 active members*
4,009 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > 1 driver 2 motors 2 directions?
    Sep 2012
    WOW, newbie here (1st post) and astounded at the number of forums/ subject on this site!! fantastic.
    So after planning and trying for years I'm almost at the stage of completing my first cnc router/mill. But after finding a few good examples, on here and other DIY machines, I'm making a few alterations to my design.
    For the Long (X) axis, i'm using a rack and pinion, and origionally I planned to use one stepper and a drive shaft to send drive the the opposite side of the machine. I didn't like this as it ment lots of pullies, and always wondered about the twist in the relatively thin driveshaft and tramping etc. I'm now much prefering the idea of using an additional stepper, so one on each side.
    To keep costs down, is it possible to power both motors from one motor driverl unit? the design means they would have to turn in opposite directions. Is it possible to reverse the direction of one stepper motor with the wiring? I think I have read that this is possible but cant find where I read it, any help you can offer is greatly appreciated.
    I'm using the following (all from Motion Control Products in the UK ++ Motion Control Products ++ (Powered By StoreSprite.com) )
    Stepper motors: FL86STH118-4208A
    Stepper driver: MSD542
    Power supply: SP407
    Many thanks, Doug
    35494
    It's not recommended, and won't work well above low rpms.
    Yes, just swap either the A with the A-, or the B and B-, but NOT both.
    Sep 2012
    Thanks ger21, would you recommend going back to a drive shaft link side to side then or would giving the extra motor it's own driver help?
    Cheers
    Jun 2007
    3738
    Two drivers, and the wires. Certainly easier than the mechanical solution.
    Just figure a nice way to start them both at zero. Mach3 can slave multiple axis.
  1. Motors wont move in certain directions!
    By mattwilcox in forum CNC Machining Centers
    Last Post: 05-24-2012, 04:10 AM
  2. Motors wont move in certain directions!
    Last Post: 04-30-2012, 03:43 AM
  3. What driver for my motors?
    By eddie3000 in forum Maintenance DIY Discussion
    Last Post: 12-08-2010, 10:52 AM
  4. Two motors on one driver
    By jakovn in forum Stepper Motors / Drives
    Last Post: 11-25-2008, 03:23 AM
  5. turning a image/model into directions for motors
    By elexolman in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-13-2008, 07:57 PM
