586,693 active members*
2,812 visitors online*
IndustryArena Forum > MetalWorking Machines > Syil Products > X4 Blinking When Turned On
Results 1 to 6 of 6
    Oct 2003
    57
    I have a 2009/2010 X4. Up to now it has worked without any issues. The past couple times I turned it on the blue LCD panel just blinks. I can shut down the main power wait 5 seconds and it may or may not repeat it. It has always turned on after two tries. Any advise? I dread the day I need it and it does not power up.
    Regards,
    Dennis
    Oct 2003
    57
    Anyone?
    Today it took almost 4 tries before it turned on. I was hoping for some advise before I took the back off.
    Syil Technical support. Any thoughts where to start or have you seen this issue / behavior before?
    Dennis
    May 2005
    925
    The machine works with the LCD off?
    Pablo
    ● Distribuidor Syil en Argentina ● "www.syil.com.ar" ●
    Oct 2003
    57
    Thanks for your reply. It has not done it again since my post. I hope it was just those couple days. I do not use the mill everyday, so I post again if it does happen.
    Where is Syil Support? Could use your insight and advise to what to do next time this happens again.
    Thanks,
    Dennis
    May 2005
    925
    looks like a loose connection or a defective power switch.
    Pablo
    Jun 2007
    3757
    With the power off, give all the crimped wire joints a gentle tug, one at a time.
    Some probably need recrimping, or will after you've pulled too hard.
    More than likely find the problem too. Don't even think of soldering any of the wires instead of crimping.
  1. Normal / Abnormal Condition blinking
    By becikeja in forum Mach Software (ArtSoft software)
    Last Post: 08-23-2021, 04:27 AM
  2. Blinking error light Fanuc 10T
    By hall6ppc in forum Fanuc
    Last Post: 05-02-2010, 05:53 PM
  3. Pro E 'blinking' problem
    By John@CRDM in forum PTC Pro/Manufacture
    Last Post: 03-05-2009, 12:21 PM
  4. help blinking red led and clicking sound
    By mberad in forum Xylotex
    Last Post: 07-09-2007, 04:07 AM
