603,373 active members*
3,855 visitors online*
Results 1 to 8 of 8
    Dec 2008
    6
    sinumerik 840c
    hello all,
    I recently found myself in a situation where a fella twisted off and I have to pick up and run with a machine called "the zayer" with an 840c...any help would be appreciated.
    thanks,
    otis
    Dec 2008
    6
    ok....how close to the 840d is the 840c?
    I am wondering if I can use fanuc drilling cyles on this mill with G290 and a G291
    also does anyone have a example of how you are stacking code for this
    controller?
    It is a bed mill with a knuckle head...
    thanks again
    Dec 2008
    6
    hey thanks again,
    Does anyone have any advise about swaping from metric to inch?
    Mar 2011
    840c
    Hello Otis
    We have a Zayer in our factory, it's a spanish machine; ours has Heidenhain control but we have also several other machines with 840C and I have some knowlege with this control...IF I caan help..
    Repbob
    Dec 2008
    6
    repbob,
    Thanks.....our machine currently reads and displays in the metric system, I would like to change it to inches. Also x and y axis' are swaped positive for negative. Its a beast 46' in the x axis.
    Mar 2011
    hello Otis,
    my compagny is closed now but I will return there on december 26 for one day and have a look to our documentation for Siemens 840C.
    If I understand well you want to change the machine from metric to inch and you want to change the sign of X and Y.
    I don't understand what you mean by " beast 46' in the x axis." Sorry english is not my mother language!
    Repbob
    Mar 2011
    metric/inch
    Hello Otis,
    1) to switch between metric/inch:
    push menu key (down right), push parameters, push bit settings, push arrow right( not the one on the keyboard, the one to expand menu), then you have a key to switch Inch/metric. But I noticed that some manufacturers cancel this perhaps to avoid errors, I don't know..
    This depends also wich soft you have on your machine.Let me know..
    2) to change the sign of one axe:
    change NC MD(MD=machine data= parameters) 564* bit 2. * means the axis number; 5640 is for first axe, 5641 for second one etc...Here also be careful, I don't know if it's OK with your soft
    Best regards
    Repbob
    Attached Files Attached Files
    Dec 2008
    6
    Repbob,
    Many thanks....its software version 5. By "beast" I mean its rather large, 46 feet of travel in the x axis.
    It might be a day or two before I can get back with the results.
    Thanks again,
    otis
  1. Sinumerik 840C, Sinumerik 840D
    By marek-vavra in forum SIEMENS -> Sinumerik 840C
    Last Post: 09-02-2022, 07:04 PM
  2. Siemens Sinumerik 840C -availability
    By S.S.Kumar in forum SIEMENS -> Sinumerik 840C
    Last Post: 06-22-2013, 11:02 PM
  3. Sinumerik 840c Screen
    By ElectroTek in forum SIEMENS -> Sinumerik 840C
    Last Post: 11-23-2012, 06:10 AM
  4. Postprocessor for sinumerik 840C
    By jorge_ocampo in forum Post Processors for MC
    Last Post: 08-12-2012, 06:44 PM
  5. Sinumerik 840c/840D drilling cycles
    By claudiu220405 in forum SIEMENS -> Sinumerik 840C
    Last Post: 01-25-2012, 07:50 PM
