586,060 active members*
3,555 visitors online*
Results 1 to 6 of 6
    Sep 2009
    75
    Fagor 8040 Error DNC
    Hi there,
    I seem to be having a problem with the sending a program from my computer to the fagor control.
    It seems to want to just send approx 8 lines of the entire program.. what am i doing wrong?
    Mar 2014
    7
    I also have cabel porblemer
    Jul 2014
    20
    Re: Fagor 8040 Error DNC
    hi,
    did you find electrical problems on the communication cable?
    how long is it?
    did you try it with 9600boud rate?
    kind regards
    Mar 2014
    5
    Hello. May be you can help me. The problem is that the СNС does not work smooth running. All the time the action takes place some sort of excerpts. Video you can see following the link ЧПУ станок - YouTube. Is this problem with Mach3 settings or in the gcode?
    Here is a quick step by step RS232 communication document:
    http://famatechnology.com/cms/wp-con...DNC_RS-232.pdf
    The cable must be shorter than 15m = 45ft and it must be shielded properly.
    Jul 2014
    20
    hello Dmitrijs
    the program is sent to the cnc while it is beeing executed? or you send the full program to the cnc memory and after execute it? one way or another please use boud rate 115200.
    besides that, it seems that you programa is generated by a CAM software. do you use G51 function or G5/G7/G50? G51 is better for cam programs generated.
  1. Fagor 8040 Error DNC
    By Xavior in forum Fagor Automation
    Last Post: 03-19-2013, 09:27 PM
  2. Fagor 8040 Lathe Threading
    By K&T EB in forum Fagor Automation
    Last Post: 01-19-2010, 03:02 PM
  3. Fagor 8040 Controller
    By cjels in forum Want To Buy...Need help!
    Last Post: 02-20-2009, 07:34 AM
  4. Fagor 8040 control
    By cjels in forum MetalWork Discussion
    Last Post: 07-15-2008, 12:46 PM
  5. Fagor 8040 Dxf Problem
    By Mert-G in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-29-2007, 10:51 PM
