586,983 active members*
3,772 visitors online*
Results 1 to 13 of 13
    Oct 2011
    Wood splitting cone program
    Hello!
    Does any body now how to write the cnc program for wood splitting cone for Fanuc 21i?
    May 2004
    4519
    Upload a drawing. Program a taper. Then G76 for a taper thread.
    Oct 2011
    Here is some drawing.
    Hope you'll get all dimensions..
    Oct 2011
    May 2004
    4519
    Profile of taper will be:
    X0. Z0.
    X111.54 Z-134.
    I think the thread cycle will be:
    G00 X115. Z14.44
    G76 P010060 Q50 R0.1
    G76 X104.95 Z-134. P440 Q50 R-57.09 F4.
    Attached Files Attached Files
    Oct 2011
    X0. Z0.
    X111.54 Z-134.
    This for taper is the last passage, right?
    Before this passage i need to make something like stairs.
    And thaen whit last passage with taper.
    Is there cycle for this?
    May 2004
    4519
    Quote Originally Posted by cigla View Post
    X0. Z0.
    X111.54 Z-134.
    Yes. Those numbers would be the final profile shape. There are canned cycles that can be used or you can manually calculate each cut. If you do not know basic CNC lathe programming, this project is too advanced for you. Start with the basics and work your way up to something like this.
    Oct 2011
    Here is drawing of my cone. Can you help me with some cycle for get this conture.
    I can write this program by writing point to point but i want some more elegant solution.
    May 2004
    4519
    So, you do not know G71 multi-pass turning cycle?
    Do you have the machine manuals?
    Oct 2011
    I have machine manuals but there are not on English language ,but German and i don't understand 100% this manuals.
    Acualy we never use G71 function until now. i now use G76 function.
    May 2004
    4519
    You need to get some English language versions of the manuals. You will be needing them.
    May 2004
    4519
    In the mean time, you can reference pages such as this:
    http://www.cnczone.com/forums/g-code...c_control.html
    Oct 2011
    Thanks i will try to do this
  1. Program splitting not wanted
    By RJSheets in forum Mastercam
    Last Post: 10-27-2020, 05:54 PM
  2. How To Make Program On CNC Wood Router
    By omnicnc in forum Omni CNC
    Last Post: 05-21-2012, 10:05 PM
  3. Nose cone
    By cncadmin in forum EnRoute
    Last Post: 01-16-2012, 07:30 AM
  4. Help With Cone
    By binfordw in forum Uncategorised CAD Discussion
    Last Post: 04-08-2011, 12:18 AM
  5. Cone Cutting in 15 mm mdf
    By SuYoG in forum FAQ of DIY CNC Machine Building
    Last Post: 12-16-2010, 10:54 PM
