587,832 active members*
3,355 visitors online*
Results 1 to 8 of 8
    Oct 2005
    42
    Shopbot code conversion
    Is there any way to convert shopbot .sbp files to standard g-code to run on mach3 software?
    Feb 2004
    9
    Should be fairly straight foreward, especially if the program was generated by PartWizard. Hand-coded SBP programs could be a pain in the neck because you'll need to run a complete simulation to deal with things like loops, gosubs, and if...then constructs. I don't know enough about g-code to guess how you'd deal with the interrupt service routine capability.
    Sep 2005
    CAll Shopbot tollfree at 888-680-4466 EST and talk to Grant. They have very good tech support.
    Mar 2004
    10
    SHP Converter
    I wrote a SHP to CNC converter a few years ago. Not sure if it supports all the current Shopbot codes, but if you are interested let me know.
    Apr 2005
    5
    The SB software has a SB code to G-code converter . You will find it under the File menu under conversions. You can find the file UX_SBP in c\Programfiles\Shopbot\Shopbot 3\ and you can copy and run the program stand alone. It shows it is a SB to DXF converter, but has an option to save as G Code.
    Apr 2005
    5
    OOPs
    c\Programfiles\Shopbot\Shopbot 3\Bin\UX_SBP
    Sorry
    Jun 2005
    90
    And there's an online converter; ShopBot Project Wizard (utility section)... so I guess you'll find a way!
    Both methods; from the control software and the Project Wiz utlilty, you'll get "BONUS" along the converter...
    My business Web site - USINUM - www.cooptel.qc.ca/~usinum
    My BLOG at Blogger - http://pacosarea.blogspot.com/
    Dec 2006
    5
    Re: SHP Converter
    Quote Originally Posted by gtsan View Post
    Hi friend, I'd be thrilled if you still have a copy of this software. Find me at robert <at> robertmihaly <dawt com>.
    Thanks a lot.
  1. Help With a DXF to NC Code Conversion
    By VNSPEC22 in forum Uncategorised CAM Discussion
    Last Post: 07-23-2016, 10:06 PM
  2. 3DReliefs.com 3D Reliefs artcam g code shopbot mechmate mach3 cnc
    By jasonmbeamer in forum News Announcements
    Last Post: 11-10-2010, 05:32 PM
  3. CATIA G-code conversion
    By osdhillon in forum G-Code Programing
    Last Post: 06-29-2010, 03:50 PM
  4. G-code conversion
    By jjfab in forum Community Club House
    Last Post: 02-10-2009, 03:29 PM
  5. text to g code conversion
    By Jiamus in forum G-Code Programing
    Last Post: 08-15-2008, 06:22 PM
