586,110 active members*
3,186 visitors online*
Thread: DNC stalling
    180
    DNC stalling
    Twice the other day while dncing new files the machine stopped motion leaving the spindle spinning. In one case there was an error message pertaining to a line with a simple XY move. The other case it looked like the transfer just stopped and the machine ran out of code.
    Any thoughts on where to look? The cable is about 15' long and the baud rate is set for 19200.
    Thanks in advance.
    Feb 2011
    423
    It could be several different things. Tell us what communications program you are running and how you have it set up.
    Aug 2009
    19
    1) Try a new cable.
    2) Try lowering your baud rate. If lowering the rate works, the chips on your communication board could be getting ready to go out.
    3) Send out on a different computer.
    Feb 2008
    547
    Which Fadal control version?
    The older cnc 88... year 89 and before would do that the cnc 88hs, I not sure about. Shaun and slowlearner have good points...if the cable and/or the baud was to high the buffer could not bump fast enough on the other end.
    Steve
    Jan 2004
    3154
    not using a good serial adapter will cause this.
    www.integratedmechanical.ca
  1. stalling ???
    By ward2699 in forum Waterjet General Topics
    Last Post: 02-10-2012, 06:43 PM
  2. HF motor stalling out
    By surrealism in forum Mini Lathe
    Last Post: 07-01-2010, 06:08 AM
  3. oh no only my y axis keeps stalling
    By stk2008 in forum CNC Machine Related Electronics
    Last Post: 09-25-2009, 11:09 PM
  4. stalling problem
    By cxixer in forum Stepper Motors / Drives
    Last Post: 10-27-2008, 03:47 PM
  5. Stalling Steppers
    By mrscheider in forum Benchtop Machines
    Last Post: 01-30-2008, 09:10 PM
