586,072 active members*
4,559 visitors online*
    Jun 2011
    26
    Unhappy Hurco VM1 Fault
    We have a Hurco VM1 and over the past few days we've had problems. It will just stop machining and bring up a x axis or a z axis fault while the light will turn itself off and on. Also you can hear clicking at the back of the machine... Then after around 10-15 mins of doing this it is fine again! Is something on its way out maybe or coolant into electrics???
    Any ideas anyone?
    Any help would be appreciated.
    Martyn
    Oct 2004
    188
    when you say the light is turning of and on, are you talking about the work light? and you get either a x or z axis following error? Sounds like it could be low voltage on the machine check the power supply test points. The 5 volt rail must be above 5 volts. what year is your machine?
    Sep 2012
    Usually something like this could be 5V power or limit switch cabel.. Does it give fault in similar situation or random?
    Jun 2008
    1104
    Re-seat the DCI/O card(s) and the I/O interface card. Also check the power cable to the DCI/O backplane card is clean and well seated.
    Dec 2012
    X-Axis and Z-Axis Fault
    Can you please provide the model numbers for the X and Z Axis drives? Also, watch the drives as this is occurring and record any displays/faults that occur. This will most likely tell us what is causing the problem
    Jason
  1. Hurco Spindle Fault
    By Ascobie22 in forum HURCO
    Last Post: 06-26-2012, 10:32 PM
  2. Hurco VMX24 ATC Overload Fault
    By Doug E. Hurco in forum HURCO
    Last Post: 12-27-2011, 08:32 PM
  3. Hurco KM3-P Servo Fault
    By nuzmeed in forum HURCO
    Last Post: 09-26-2011, 04:11 PM
  4. Replies: 8
    Last Post: 09-09-2011, 02:01 PM
  5. hurco vm1 x axis fault
    By merv385 in forum HURCO
    Last Post: 11-23-2009, 09:20 PM
