587,006 active members*
3,126 visitors online*
IndustryArena Forum > CAM Software > SprutCAM > Hole Machining - Deep Drilling Cycle in Sprutcam
    Feb 2012
    Does anyone know what to set the values at in the deep drilling parameters to get the drill bit to peck .075 and then only retract something like .050 instead of coming all the way out of the hole?
    Ken
    Jan 2012
    714
    There is a peck drilling cycle that does this (drilling with chip break), there are two values to set for it, the default doesnt work, it gives an error message so I change the top value to .031 instead of .0031 and it works I use this on .112 holes .625 deep in aluminum.
    I havent used the deep drilling cycle where the drill comes out of the hole on the parts I make.
    mike sr
  1. Deep Hole Drilling
    By Snowie in forum G-Code Programing
    Last Post: 03-09-2013, 07:43 AM
  2. Deep Hole Drilling
    By Tornos100 in forum CNC Swiss Screw Machines
    Last Post: 02-27-2013, 10:57 PM
  3. Deep hole drilling
    By Veracity in forum MetalWork Discussion
    Last Post: 06-17-2011, 03:40 PM
  4. G83 deep hole drilling
    By mike852 in forum Community Club House
    Last Post: 02-08-2010, 07:34 PM
