586,065 active members*
4,301 visitors online*
    May 2003
    323
    Witch machine to buy?
    Hello
    Looking for used cnc mill 3 axis.
    Machine height can not be more then 7 ft.
    Trying to put the machine in the office type building.
    Garage door opening max 7 ft.
    Any help is appreciated.
    Thanks for reading.
    Sep 2012
    117
    I'm a noobie as well , depends on what your wanting to do.
    I started with a shopmaster Patriot (it's for sale) , a little more travel in X & Y , has a lathe , running 3 axis , has 4 axis controler
    Just bought a Tormach 1100. I'd say it's a MUCH better all machine over all for what we do.
    NOTHING wrong with a Shopmaster , I wouldn't be doing what I'm doing if it wasn't for them. A GOOD way to find out if you want/like CNC work.
    Apr 2002
    5003
    Is the 7ft the room heigth or only the door height. Many vertical mills will moved, with the Z-axe down. Therefore they are some half yard higher at work. My big 5 ton machine with the dollies under the machine fits into a door with 7ft height and wide.
  1. Replies: 5
    Last Post: 01-08-2023, 09:09 AM
  2. witch type of motor?
    By sml2010 in forum Servo Motors / Drives
    Last Post: 08-25-2011, 09:16 PM
  3. witch CAD/CAM software with MACH3 ??
    By rontron in forum Mach Mill
    Last Post: 12-18-2009, 08:38 PM
  4. Witch milling machine to buy for CNC retrofit?
    By Sperstad in forum Vertical Mill, Lathe Project Log
    Last Post: 02-10-2007, 05:21 AM
  5. Witch stepper motor?
    By Marc in forum Stepper Motors / Drives
    Last Post: 05-10-2005, 07:58 PM
