588,653 active members*
6,400 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Turn off spindle during program execution stop
    Oct 2005
    332
    Lathe machine with a 21iT.
    I would like to know if what I want to achieve can be by parameter change or if I must edit the machine ladder.
    In my work is often needed to stop the program execution (in the controller is shows MEM HOLD), while the machine is not cutting (after a retraction, for example). In this case sometimes, I want to be able to stop the spindle simply by pressing the spindle stop button.
    I use this for cleaning the material.
    After that, pressing the RUN button, the machine should resume the work AFTER the spindle is on again.
    I worked in a machine with the functionality that I am describing and I would like to implement on a new machine that I have now.
    Thank you for any information
    Oct 2005
    332
    For future reference I was able to achieve this by changing the ladder.
    Dec 2012
    395
    Just before you want to stop put your [ Single Block ] ON.
    Finish that line and make a [ Spindle Stop ], clean your product or do something else, after this, put your machine on [ JOG ], start the spindle [CW] or [CWW] and back to [ Memory ], [ Single Block ] OFF and push [ START ] button again, program will proceed.
    Maybe later you can change the Ladder diagram or a parameter but for now this must work.
    Heavy_Metal
    The Netherlands.
    Sep 2011
    78
    @ heavy,
    With my mach. a accuway with oi-tc controll when i switch from memory to jog the spindel always stops. I dont want this but want it to keep running til i press spindel stop. when i press spindel CW the spindel stops again when switching to mem. I always have to do M3 in MDI before switching to memory and resuming work. Any idea's??
    Groeten
  1. Replies: 9
    Last Post: 07-05-2012, 08:57 AM
  2. Fanuc 18: macro program execution speed
    By xingchengting in forum Fanuc
    Last Post: 08-27-2011, 01:01 AM
  3. Fanuc OM Program Execution
    By Camber in forum Fanuc
    Last Post: 04-20-2011, 11:44 AM
  4. Spindle doesnt stop at end of program
    By S Woods in forum Fadal
    Last Post: 07-24-2010, 12:29 AM
  5. eliminate start and stop of spindle for short program?
    By endgrainguy in forum G-Code Programing
    Last Post: 06-09-2009, 03:06 AM
