586,077 active members*
4,039 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > TC for Mac.. CAM? w Taig + Trunnion Tble
    Oct 2012
    I've decided on a Taig machine and will be running a trunnion table.
    Mostly I'll be making golf putter heads, which requires some tricky toolpaths - to produce smooth flowing lines. The rounded 3D lines, design intricacies and such are a high priority with regards to quality.
    I've done some research and I'm in a bit of a spin at the moment.
    I'd appreciate any thoughts on the perfect CAM package for this type of thing...
    Apr 2004
    5737
    You might try DeskProto. They've recently added some 5th axis (trunnion) indexing routines, which can approach the work at different angles, although it's not the same as continuous 5-axis machining.
    Andrew Werby
    www.computersculpture.com
  1. Trunnion on VM1?
    By mafitch7479 in forum HURCO
    Last Post: 11-30-2011, 10:15 PM
  2. Trunnion for the 1100 ....
    By twocik in forum Tormach Personal CNC Mill
    Last Post: 07-17-2011, 04:58 AM
  3. Trunnion table
    By Scottluther in forum Benchtop Machines
    Last Post: 02-27-2011, 11:57 PM
  4. Trunnion Tables
    By H_U_S_S_A_M in forum Haas Mills
    Last Post: 04-20-2008, 09:02 PM
  5. Trunnion Table for 5-axis
    By Zumba in forum Uncategorised MetalWorking Machines
    Last Post: 05-02-2006, 04:09 PM
