603,890 active members*
3,993 visitors online*
IndustryArena Forum > MetalWorking Machines > Hitachi Seikis > Machine Parameters for Hitachi Seiki TF15
Results 1 to 8 of 8
    Jun 2012
    For our Hitachi Seiki TF15, with mount robot mr6, Seikos III we are looking for the machine parameters and the ladder diagram. Unfortunately we have lost them, because baterry has run out, and was replaced too late.
    Is anybody, who would have the parameters or the ladder?
    I would really appreciate any useful informations.Thanks in advance!
    Dec 2009
    559
    Hello, I have the information you require, what version was the ladder?
    John
    Jun 2012
    Hi John,
    I wanted to send you a picture from the manual, but it did not worked out.
    Is this, what you could use?:
    Model code 1531 drawing number Z01E
    and
    Model code 1531 drawing number A10T
    Alex
    Dec 2009
    559
    Alex,
    that works. I do not have that exact revision, but what I have should work for you. Its a newer version, so it will have everything you need. Can you PM me your email and I will send you the ladder files. I am still working on the parameters.
    John
    Nov 2013
    Hi John,
    we have the same problem now which you have probably solved last year with Alex.
    Could you help us as well?
    Balazs
    Dec 2009
    559
    Balazs,
    what is the version you are looking for? And what do you need me to send?
    John
    Nov 2013
    Hi John,
    sorry for the delay; we have had some contact to Alex and tried to solve the problem that way.
    Our problem is as follows:
    * we have a TF15 which contains two TF15 mashines build togheter with robot loading originally by Hitachi and
    * the machine has not beed used for the last two years.
    * we have lost the parameters now.
    What we would like to ask you to send, are the parameters as we only have them in written form.
    I made some pictures of the machine and of the machine numbers, etc., if it helps you.
    Can you help us with that?
    Many thanks,
    Balázs
    Dec 2009
    559
    Balazs,
    so you have all of the parameters on paper? The easiest thing to do is load them by hand, as you wont be able to load them automatically until you enter the parameters for communication manually. There are not too many on that machine so it wont take too long,
    John
  1. Hitachi Seiki 4NE-600 parameters
    By padams in forum Fanuc
    Last Post: 03-08-2019, 08:44 PM
  2. Parameters VS50 hitachi seiki
    By Rocket_Col in forum Fanuc
    Last Post: 11-22-2011, 12:03 PM
  3. Did Mori Seiki Buy Hitachi Seiki?
    By Billet Sean in forum Mori Seiki lathes
    Last Post: 05-05-2011, 04:12 AM
  4. Fanuc 5T Hitachi Seiki Parameters
    By TechnoJunkman in forum Fanuc
    Last Post: 02-17-2011, 12:43 PM
  5. Hitachi Seiki Fanuc 11M Parameters
    By diegojulio in forum Vertical Mill, Lathe Project Log
    Last Post: 03-03-2009, 12:33 AM
