Supply with CE certificate
In-line ATC Wood CNC Router Equipment
Features: SYNTEC control system:separate keyboard control system,easy to learn and convenient to operate.The customers are able to master the application in a short time. Advanced numerical control system and intelligent anti-transgress-process protection system,this function could prevent machine,crashes when the design zone is beyond the process zone.
Intelligent process speed control,this function could control the process speed,which could increase the efficiency,prolong the cutter life and increase the rate if finished products.
Dust-suction system:the dust suction system could absorb the saw dust and keep machines clean,which maintains equipments as well;the dust suction system take place of the physical flat fixation which save the time of load and unload time of slabs. Advanced file pretreatment can correct the error in the files and is compatible with the process codes of multiple national and international software(such as mastercam,typ3,UG,caxa). Advanced 3D space curve prediction algorithm can make sure of the evenness of polyline and the speed and precision of curve lines.
Main axle rotating speed:0-18000/24000rpm/min
Work mode:servo
X Y Z working area:1300*2500*200mm/1500*3000*200mm/2000*3000*200mm
Table size:1480*3000mm/1680*3500mm/2180*3500mm
Max feeding:>30m/min
Work holding:by suction
Interface:USB
Command:Gcode*.u00*.mmg*.plt
Surroundings for software:win98/2000/XP
Power(not include the spindle):4000W
Power:AC380V/50HZ
Guide rail:three axis quare rails(imported from Taiwan HIWIN or AMT,)
[email protected]
