586,974 active members*
3,214 visitors online*
Results 1 to 5 of 5
    G0704 5th axis
    I've been looking at Hoss's videos on the 5th axis and am thoroughly impressed and jealous.
    I get how the head is attached to the "table" part of the rotary table; through the 3 bolt mod, but how is the rotary table is attached to the slide (on the column side)?
    I don't recall any details of that in the videos.
    adrian.
    4 carefully placed mounting holes and machining the flange down to fit inside the rotary.
    Hoss
    Attached Thumbnails Attached Thumbnails 5th axis 30_800x600.jpg   5th axis 32_800x600.jpg   5th axis 33_800x600.jpg
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    Jan 2012
    469
    Haha.. Clamping the head on a vise! That is brilliant, I would never have thought of that!
    Thanks Hoss.
    Holding the head in the vice IS brilliant!
    It would have made the assembly simpler if the rotary table had 3 T-slots instead of 4, would it not?
    Did the under-side of the rotary table need to be modified much?
    adrian.
    Nope, not a bit.
    Hoss
  1. G0704 Z-axis Disassembly
    By Titaniumboy in forum Benchtop Machines
    Last Post: 10-11-2012, 07:26 PM
  2. G0704 need some tips on Z axis
    By macatoms in forum Benchtop Machines
    Last Post: 04-26-2012, 01:57 AM
  3. G0704 Z axis conversion
    By pemko in forum Benchtop Machines
    Last Post: 04-16-2012, 02:40 AM
  4. G0704 X axis conversion
    Last Post: 02-28-2012, 03:07 AM
  5. New G0704, need 2 or 3 axis DRO kit?
    By wildonewest in forum Benchtop Machines
    Last Post: 12-31-2010, 05:23 PM
