586,113 active members*
3,594 visitors online*
Results 1 to 12 of 12
    Jun 2010
    24
    Brother Wire EDM HS100
    Hi folks,
    I have just purchased an old 80's W-EDM machine and looking for any kind of documentation for this HS100. Priority if possible to find schematics for power supply and all otrher circuitry as well.
    I have the users manual in Swedish so I think that part is covered as I read/speak Swedish.
    So whatever documentation you may have or can link to would be appreciated.
    Cheers
    Bengt
    Feb 2008
    27
    Brother manuals
    I have some manuals for this machine, I owned one a long time ago.
    I will try and find them if you wish.
    Regards
    Jun 2010
    24
    Gday Skeney,
    Would you be so kind and have a look for the documents.
    Cheers from Sweden
    Bengt
    Jun 2010
    24
    Also very much interested in getting a copy of Brother QD-2 or QD-3 software for win3.1(or DOS) on 3,5"FDD or zip archive via e-mail.
    Jun 2010
    24
    Here a heads up, still looking for users manual for the WEDM HS100
    HS100 first cut - YouTube
    Now I have the machine working but still in need of manual to get a grip of all parameters that can be set.
    Cheers from Sweden
    Bengt
    Jun 2010
    24
    Hello again from Sweden,
    Still looking for documentation for this HS-100
    Anybody out there who is using or remembers what 'System Constant' in machine setup is for?
    I have hand written notes that states this setting to be '3' but would like to know what is stands for.
    I have managed to repair a floppy with QD-2 software and would like to get Communications via RS232 Cable working.
    If I understand this correctly in QD2 the setting NC is for Brother's proprietary opto-link, is the tape reader setting for RS232 output?
    So, how do one setup the HS-100 to do all Communication via RS232 Cable and not use the Opto-Link?
    Any hints of how to settings should be in PC and HS-100 are welcome, would like to get comms working and avoid manual G-code Writing on HS-100
    Cheers from Sweden
    Bengt
    Jun 2010
    24
    Any help in this matter would be very much appreciated.
    Cheers
    Bengt
    Jun 2010
    24
    Hi folks,
    I have managed to get hold of documentation in Swedish for my HS100
    Case closed
    Cheers
    Bengt
    Jun 2010
    24
    There is one document that I cannot get my hands on, with each HS100 there is a document with tables showing feed's and speed's for different brass wires/materials.
    Anyone out there that have this document and have the possibility to copy and make PDF of it or willing to send a paper copy via post would be much appreciated.
    Merry Christmas everybody
    Bengt
    Re: Brother Wire EDM HS100
    Hi can any one record a video working in the machine
    I just got one hs-100 and i cant get it working thanks
    Re: Brother manuals
    I'm in a big problem
    I want an old machine manual (Brother HS-3100 wire cut machine)
    Please if you know any source I can find it from
    Mar 2016
    Re: Brother manuals
    Quote Originally Posted by AhmedFekryGalal View Post
    Hi, I have all the manuals. Do you have parameters for this machine ?. Regards,
    Ernesto.
  1. BROTHER HS-3600 WIRE EDM
    By MAN39ER in forum EDM Discussion General Topics
    Last Post: 08-21-2022, 06:54 PM
  2. Problem with Brother Wire EDM
    By JINX222 in forum Waterjet General Topics
    Last Post: 07-30-2022, 11:34 PM
  3. Want Brother HS-70A or HS-70AM wire EDM
    By NoSurprise in forum Want To Buy...Need help!
    Last Post: 07-17-2012, 06:59 PM
  4. Brother Wire Edm
    Last Post: 01-28-2007, 10:46 AM
  5. Brother Wire Edm
    By JINX222 in forum Plasma, EDM / Other similar machine Project Log
