Ok. I would like to invite all those who are making a "torsion box" router and all mechanical engineers here to participate in this.
I have seen that many people are building torsion boxes. Very neat and excellent execution (esp. if you have a cnc router to begin with).
What struck me the instant I saw the first torsion box was "what a waste".
I shall explain:
After having read some books on space-frame design (from the racing car chassis design neck o' the woods) I often find myself looking at various structures around me, like buildings, bridges, cars, whatnot, looking for triangulation, looking for monocoque, spotting mistakes, appreciating well exectuted designs etc etc.
And I really think I can spot a valid space frame when I see one.
To elaborate on the "space frame" malarky so the uninitiated don't accuse me of talking gibberish, basically a space frame is a structure designed to connect 2 or more points in 3d space such that the connection is ultimately as stiff as possible. Does that make sense?
Now, the best way of connecting 2 points in space AB is with a straight line. The best way of connecting 3 points in space ABC is using a triangle. I don't need to elaborate on this further as since you are allready here it means you are literate, if you are literate then you definitely understand what a triangle looks like.
Turns out that connecting 4 points in space ABCD is also best done with a triangle. Not one but multiple triangles. Well 3 really. ABC, BCD, CDB, done.
Remember that we are creating for stiffness. You can do it with stainless steel rods. Well you can do it with matchsticks equally well. It'll be just as stiff.
So our torsion box, once we have "triangulated" it looks something like picture 1! Ok, I've left out a few diagonal links there which would probably confuse some people, but you get the general idea. Triangle, triangle, triangle...box of triangles.
Now, turns out that you can actually fill in the void between sides of our triangle with material and it won't hurt the performance of the spaceframe one bit, in fact it'll better it somewhat. And so we get to the infamous "monocoque". And now our torsion box looks something like picture 2.
Reminds you of a box, doesn't it? In fact it IS a box. Hidden from view are only 4 internal braces (those missing from picture 1 above) going diagonally to connect the opposite edges of our box in effect triangulating those as well.
So here's my tip:
next time you want to make a torsion box you may only need to cut the "skin" for it and those 4 diagonal braces for the innards. And you will be left with equally functional torsion box and a heap of MDF to use for something OTHER than making millions of internal braces for it...
:cheers:
