I had my machine transported and the table came loose and crashed into the tool setter. I replaced the probe but now the tool probe center is out by about .250". How do I adjust the center?
Thank you
Thank you
Download the manual from the Renishaw site, it should have the parameters that store the location of the probe as I remember - which you will need to correct. This is assuming you're using the Renishaw programs for tool probing, if you're using custom macros you'll have to read through and find the locations referenced in the them and then fix those (you can also do this with the Renishaw macros).
Ok I'll try that. Thanks for your help.
