586,114 active members*
3,348 visitors online*
Thread: M code list
Results 1 to 8 of 8
    Jan 2012
    16
    M code list
    I have a mori seiki SL_15m with fanuc MF-T6 control ,I don't have any operator manual .
    Does anyone have the M codes list for this?
    Aug 2011
    2517
    it's a Fanuc 16T control. You can use any Fanuc 16/18/21 manual for basic operation. I have all the Mori info, but first......
    do you have live tools/c axis? tailstock? steady? etc etc? what is the spec of your machine. or post a few pics......
    Jan 2012
    16
    I want to know that, which M codes is for tailstock ?
    My machine has live tools and C axes and tailstock.
    Aug 2011
    2517
    is it a tow-along type (i.e. programmable positioning of the body), or manually clamped with a spanner?
    Jan 2012
    16
    tailstock is manually,we can move it only forward or reverse with pedal.
    Aug 2011
    2517
    ok well all you can do is program quill in/out, that's M26/M25
    Jan 2012
    16
    I checked M25/M26 but I didn't see any reaction. I think one of the keep relay (K pmc parameter) is not active.
    Aug 2011
    2517
    are you sure it's programmable? it may only be a manual tailstock activated with pedal and push buttons on the panel.....
    there is only one keep relay parameter related to the tailstock.
    K7 bit 0 is 1 if your tailstock is programmable and 0 is it's manual only.
  1. SCM / Xilog g code & m code list?
    By Finndus in forum Commercial CNC Wood Routers
    Last Post: 06-30-2019, 12:20 AM
  2. G-code list
    By davek in forum G-Code Programing
    Last Post: 10-04-2010, 02:06 AM
  3. EDM G-code list
    By mn12mike in forum G-Code Programing
    Last Post: 06-13-2008, 12:52 PM
  4. AB 8200 g code list
    By tman66 in forum G-Code Programing
    Last Post: 04-23-2008, 09:37 PM
  5. G & M Code List
    By kbcnc in forum Uncategorised CAM Discussion
    Last Post: 04-28-2003, 06:42 PM
