586,104 active members*
3,377 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Which metering fitting goes where?
    Jul 2006
    24
    I have a BMC-20 machine and just cleaned up the autoluber and didn't notice which fitting went toward the head and which went toward the table in the tee block that is fed from the autoluber unit. I have a FJB-3 and a FJB-4 for fittings. This is just the start of my cleanup. The "Y" ways are pretty dry and I am thinking of removing the table from the machine to clean out the grooves. I have read most of the posts on lubing this machine and will be using the info as I progress. Thanks for any info.
    Steve
    Jul 2006
    24
    Just talked to Steve at Hurco and he mentioned the 3 goes toward the head and the 4 goes toward the table.
    I am trying to remove the lid to the lube motor to tighten the motor housing back down to the tank lid. My problem is there is no visible means of holding this lid to the motor housing. I tried gently prying on it but because the housing is loose on the tank lid I didn't put a lot of effort in to it. Any body familiar with this?
    Steve
  1. LUBE metering unit size ?
    By D.D.Machine in forum Fadal
    Last Post: 10-12-2011, 04:30 PM
  2. Lube metering unit rated flow
    By TarHeelTom in forum Bridgeport / Hardinge Mills
    Last Post: 09-22-2010, 07:15 AM
  3. Lube metering unit
    Last Post: 08-20-2010, 03:33 AM
  4. metering valves for one shot oilers?
    By thomasfreedy in forum Benchtop Machines
    Last Post: 03-31-2009, 05:35 PM
  5. Metering/Dosing pump
    By pds in forum Mechanical Calculations/Engineering Design
    Last Post: 12-03-2008, 09:31 PM
