586,075 active members*
3,984 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Which files to copy?
Results 1 to 6 of 6
    Dec 2010
    20
    I am upgrading to a new computer and will install x4 mu2. I am currently running on a laptop and need to know which files to copy after the new install (config,machdef, etc)
    Thanks for the help
    May 2004
    4519
    Configurations, machine definitions, control definitions, post processors. Can't give exact file names because we do not know what you may have added or modified.
    Jun 2007
    3757
    Look for files that are later than the original install date.
    Sort in file explorer by date created probably will work.
    This applies to lots of software in a windows environment.
    Probably in multiple places on the computer too.
    Oct 2006
    104
    Do a search of your hard drive for mcamx6. There will usually be 3 main folders. mcamx6 (main program install folder) Shared mcamx6 and my mcamx6 The shared mcamx6 and my mcamx6 folders will be the ones you will want to copy and replace on your new install However if you are going upgrading to win 7 from xp the files will have to be put in different locations than they are in xp. How do I know this...did 3 installs on 3 computers in 6 months.. good grief
    Oooops my bad...if you are transplanting x4 search for x4 and so on.
    Jun 2007
    3757
    snkdriver can search for mcamx6 all he likes.
    It's X4 he needs to transplant.
    Apr 2003
    3578
    Sorry but please do not follow Neil20 or Serjack as this two options will not give you good results. as for sure there were major changes between X4 and X6 directorys and you stated X4.
    Now what are you wanting to move over beside the CNC_Machine and say the Mill folder these will contain the Machines and post files along with tool libraries and Material lib's that you made on the laptop.
    Now are you looking to move over your configaration of MC?
    Cadcam
  1. Converting Illustrator files to Gcode files
    By acoop101 in forum Uncategorised CAM Discussion
    Last Post: 03-10-2023, 11:13 PM
  2. Replies: 2
    Last Post: 01-16-2016, 03:23 AM
  3. Convert files to Inventor files.
    By bartL in forum Autodesk
    Last Post: 02-04-2009, 06:38 AM
  4. Files to copy accross
    By Prboz in forum Mach Mill
    Last Post: 02-13-2007, 03:21 PM
  5. anyone have a copy
    By NCcustom in forum Mastercam
    Last Post: 02-02-2006, 03:46 PM
