586,036 active members*
3,490 visitors online*
    Oct 2011
    65
    mc data missing
    When I load program from Partmaker into our Citizen K-16E. I get an error stating illegal data format. I looked a little closer and noticed some of the specs. for toolholders were missing. Anyone else have this? I,m loading this on a flash card.
    Oct 2008
    108
    Are you using the correct post processor for the K-16 from Partmaker?
    www.atmswiss.com
    Jan 2013
    MC-Data...
    Quote Originally Posted by colby2000 View Post
    Post the code or send it to me in txt format and I will load it to see if I get the same errors. Then, correct if so, save, and send it back to you.
    [email protected]
    or [email protected]
    Dec 2008
    54
    Make sure your cutoff process is the last process on the process table. This needs to be done to have the MCData correct.
    There may also be some different options on your machine and we may need to customize the MCData for you. If the above does not work, contact [email protected].
    Bill Cain
    www.partmaker.com
  1. mc data missing
    By colby2000 in forum Uncategorised CAM Discussion
    Last Post: 01-29-2013, 02:13 PM
  2. Missing M30
    By skeeter21 in forum GibbsCAM
    Last Post: 05-08-2012, 11:37 PM
  3. all missing
    By istotel in forum Fanuc
    Last Post: 01-21-2010, 10:17 AM
  4. X3: Missing V in my VFD
    By imprez55 in forum Benchtop Machines
    Last Post: 01-03-2010, 03:02 AM
  5. File numerical data missing in GriffoBros
    By iprogcnc in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-20-2007, 03:48 PM
