Hello.
On a AC motor the plate informs:
150 VAC
15.3 ~A
Connection (symbol below)
For a granite VSD-E the max ratings are 160V DC and 10A DC, accordingly to the manual the output voltage is at max 88% of the input voltage. So voltage I can understand correctly, and I know I will get less max RPM. That is fine.
Now the amperage = torque... The drive is 10A DC max continuous, what will give in AC? The motor clearly indicates Amps in AC, as the plate is ~A, so I get confused finding if it is suitable for this motor.
The star connection also indicates the pole number? in this case would be 6?
Thank you
