586,635 active members*
3,306 visitors online*
Results 1 to 9 of 9
    Apr 2005
    903
    Small part fixture
    Looking for some input on how I might fixture this part for the second op on the back side. I would like to machine one surface then turn over and face off, then fixture to finish.
    I have made a lot of similar parts machining both sides, then machining the part "out of" the stock. However this method leaves a little "hook" than needs cleaned up by hand, plus the machining is never as clean as I would like. This way ends up leaving chatter marks on the part in the area leading up to the part coming loose from the stock.
    I've never worked in a machine shop so I haven't seen any cleaver fixturing ideas or systems, I'm just winging it.
    Any ideas?
    Part is about 1.25" tall.
    2008 Haas VF2D
    OneCNC XR5 Mill Expert
    May 2004
    4519
    Use soft aluminum jaws in a vise and cut out the female of your part. Start with stock that is about 0.125" oversize in thickness and then overcut your part height into the stock. Be sure to cut away the extra on the corners. Then place your part into the soft jaws to face off and finish as needed.
    Apr 2005
    903
    Where is the cheapest place to get soft jaws?
    2008 Haas VF2D
    May 2004
    4519
    But some aluminum bar stock and make your own.
    Apr 2005
    903
    yea that's what I was thinking, I found some on ebay for $18, but they will only make a few minutes to make.
    2008 Haas VF2D
    Jun 2007
    3757
    For low quantity parts I machine my holding jigs out of hardwood, or just about any scrap that comes to hand.
    Often machining the female shape, adding a handsaw slit and crushing in the machine vice.
    Some are drilled, tapped and screwed, then the saw cut added.
    Old red gum from fence post is just great.
    Jul 2005
    12177
    If you have two vises lined up adjacent to each other you can make very quick and simple custom jaws just using some short pieces of bar. Grip a peice in the left vise long enough to reach across the other vise; that is your fixed jaw. A short piece in front of it in the right vise becomes the moving jaw. The pictures in the links show the idea; very quick, very simple and even practical for a one off part.
    http://www.cnczone.com/forums/attach...6&d=1262330175
    http://www.cnczone.com/forums/attach...7&d=1262330175
    Jun 2007
    3757
    That's neat!!
    Apr 2005
    903
    Thats interesting Geof, thanks.
    2008 Haas VF2D
  1. Help with multi-part fixture
    By Pharkas in forum MetalWork Discussion
    Last Post: 09-12-2012, 04:07 PM
  2. How to (easily) fixture the second side of this part
    By vandal968 in forum MetalWork Discussion
    Last Post: 12-17-2011, 03:09 PM
  3. How to fixture a part?? ...see post #10 for print
    By SSN Vet in forum MetalWork Discussion
    Last Post: 03-13-2009, 10:03 PM
  4. Making a fixture cavity from 3d part
    By Shepard in forum Mastercam
    Last Post: 04-10-2008, 03:18 AM
  5. Fixture for holding 31/32 Round Part
    By Smackre in forum Work Fixtures / Hold-Down Solutions
    Last Post: 06-03-2007, 02:24 PM
