586,113 active members*
3,209 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Live tooling tutorial
Results 1 to 11 of 11
    Oct 2012
    6
    Question Live tooling tutorial
    Greetings! I have been looking through the site for a while had many questions answered by using the search function. However I can not find anything on programming for live tooling. I can not find any tutorials on it or generating the cad for it either.
    I run a machine shop in the Navy. I have 5 CNC machines (SL-20, ST-20, ST-20 live tooling, toolroom mill, and a waterjet) All of my CAD-CAM knowledge is self taught. Between tutorials and manuals I can usually get the job done.
    Does anyone know where i can find a live tooling tutorial or direct me to a distance training program or DVD that will cover this that is not exorbinantly expensive? (If it isn't in the Navy's "accredited" schools list this is out of pocket for me)
    thanks for any help!
    Jan 2006
    2985
    No experience with it but here is a possible option:
    Featured products
    Just the lathe part, dirt cheap: http://www.emastercam.com/board/inde...do=item&id=266
    Matt
    May 2004
    4519
    I assume by "live tooling" you mean for the ST-20 lathe. Many times it is more efficient to program these operations manually and not rely on the CAD/CAM (face drilling, cross drilling, milling flats or slots).
    Jul 2011
    218
    There is 2 in the mcam lathe tutorial book
    Not much more that I know about
    CHOCLATE? THIS IS DOODOO BABY!
    Apr 2003
    3578
    Cadcam
    Oct 2012
    6
    Quote Originally Posted by txcncman View Post
    Ok then how do I manually program flats on a ST-20 with a 5/8 endmill to an 18mm flat to flat (9mm radius) dimension?
    Stainless steel with a 1.125in OD.
    May 2004
    4519
    With Y axis? Or X and C only?
    Oct 2012
    6
    x and c.
    May 2004
    4519
    For X and C only, I think it would be something like:
    (You put in the Z position.)
    C0.
    G01 X0.875
    X0.6668 C50.9558
    X0.875 C101.9116
    G0 X1.
    C180.
    X0.6668 C230.9558
    X0.875 C281.9116
    G0 X1.
    But that might not give you true flats. You might have to include a radius in the tool path. Been a while since I have done this.
    May 2004
    4519
    Yeah, you will have to switch to Cartesian (G112) and G17 plane and program it as X and Y. See page 145 of the lathe manual for an example.
    Oct 2012
    6
    Thanks. I am a lot closer than I was 20 minutes ago. I appreciate it!
  1. Replies: 2
    Last Post: 08-09-2010, 04:17 PM
  2. diy live tooling
    By seawolf217 in forum Haas Lathes
    Last Post: 06-09-2009, 04:07 PM
  3. SDU/live tooling
    By tox in forum Okuma
    Last Post: 12-01-2008, 08:44 PM
  4. What is Live tooling versus "non-live tooling"?
    By squale in forum Uncategorised MetalWorking Machines
    Last Post: 11-15-2007, 09:38 PM
  5. Need help with live tooling on cnc vtl
    By YV600 in forum G-Code Programing
    Last Post: 07-02-2007, 03:29 AM
